Old 02-28-2005, 07:06 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Re: A question for all you DSMers
Originally Posted by street_racer_00
Okay, I don't know shit about DSM cars, either 1st or 2nd gen, but is the 14b the stock turbo on the 4G63?
yes it is. the most common upgrade is a 16g of some sort.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-28-2005, 07:08 PM
kjewer1 kjewer1 is offline
AF - Advisor
Yes it is. And 10.5's statement that boost pressure is a reading of airflow that can not get though the motor is absolutely correct. Think of boost as excess airflow. Some of that excess airflow will get through the motor, some wont. As pressure goes up the force pushing the air through the motor goes up, so you do get more through. But looking at PV=nRT, pressure is heat, and the inverse of density. That what we are talking about when you get to that point of diminishing return, where you are geting sliiightly more airflow, but LOTS more heat.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-28-2005, 07:09 PM
Gsx_hooptie Gsx_hooptie is offline
Manual 1g turbo's had a 14b. Auto's turbo 1gs had a 13b, smaller. 2g turbo's, both manual and automatic, had a t-25. The 14b is the best of the bunch.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 02-28-2005, 09:07 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
shit I have a eclipse and im still lost in this turbo stuff I dont know much about this at all but thats why we are here is to learn.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 03-01-2005, 01:20 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
A lot of good info in this thread, but unfortunately it can't all be asked and covered. Some of the ideas that most people might not understand are:
1. A boost gauge reads boost that is NOT going into to the engine. (thanks 10.5sec92AWDTALON)
2. psi doesn't equal power, here's a short explanation: boost pressure (psi) can only be compared to another pressure if you're talking about the same engine, turbo, and mostly the same supporting mods. Say I installed a part which let the engine flow better. It's not hard to imagine that the boost gauge would read less. The air that couldn't go into the engine before can now.. less boost, more power. There are many other examples.
There are a lot of theoretical things that are hard to guess at. If you learn how things work in reality (example: on a 2g turbo, t25, 16psi DOES make more power than 14psi), you will get the concepts afterwards. Why isn't 20psi on a t25 faster than 16psi? Well, it sounds like it should be, but for the minimal power it does make in the mid-range of the RPM band... it creates a lot of heat which makes 20psi a bad idea on pump gas, which will detonate at such heat.
Anyway, I'd be happy to stab at other concepts but don't forget that everyone looks smarter if they do their research first then ask a specific question instead of saying "I don't know anything about turbos, what is a wastegate" etc... A lot of knowledge is just experience and hearing that 16psi on a t25 is faster than 14psi, or that you can run about 25psi on a 14b. Only some of it is knowing that, say, a certain turbo would be more efficient.
Old 03-01-2005, 06:37 AM
AF - Advisor
Just because I'm in a good mood, and I'm putting off dropping a mean deuce that is probably going to cripple me, I'll explain my favorite "concept." Since it applies to this thread...
Boost vs Airflow and volumetric efficiency and displacement. As I stated earlier in this thead, I think, more airflow at the same (or less) boost, is the balls. Airflow is power, boost is heat. Now, to offer some tangible measureable data. On a 2 liter, its typical to get 40 lbs/min at 20 psi on a decent sized turbo (20g and up) and stock cams/intake/head. Add cams to that, and you get ~4 lbs/min improvement in flow at that same boost. Thats a 40 hp increase, without adding heat (knock). The added cylinder pressure (cylinder pressure and power are the same, or more acurately, torque, but both are mathematically linked anyway) will increase the chances of knocking but its very linear and predictable (unlike increasing timing, which can increase cylinder pressure (knock) exponentially after some point).
25 psi was good for 47-48 lbs/min, or about the max a 20g will do. Note that at 25 psi a 16g will do ~35 lbs regardless of cams/mods, since thats its limit In the case of a 14b, 30 lbs/min at 25 psi. A sheetmetal intake is good for a few more pounds of airflow at the same boost.
All this added airflow is added power, without added heat (boost, see ideal gas laws/adiabatic compression). This is bigtime if you are running pump gas! Race gas will "bandaid" all this BS, and thats why you can max out 16Gs and 14Bs and not knock, on relatively stock setups.
Add a stroker into the mix and things get real fun. 20% displacement increase will yield 20% airflow increase if VE remains constant (unlikely, but its close enough). This is how I was able to hit 64 lbs/min at only 29 psi last time at the track. I was getting 60 lbs/min on a 60-1 at less than 25 psi. I ran that on pump gas with no knock.
Its important to note that if you increase a motors volumetric efficiency (cams, head, intake, larger turbine wheel, free flow exhaust, less restrictive MAS, etc) beyond the flow capabilites of the turbo, boost will drop as demand goes up. This is exactly what you see with a t25 on a stock 2g set to say 18 psi. Once the turbo can keep up with airflow demands, airflow will flatline and boost will drop. Note that boost is dropping, but airflow (power) is not! I've datalogged this on several setups. Take a 20g car with cams and sheetmetal intake set to 30 psi, and you will see the same thing, boost dropping at high rpm, airflow maxed out. In these cases, less boost is not less power. The two are not perfectly linked like people tend to think.
So I hope that people at least pick up on the relationships between boost, heat, knock, cylinder pressure, and power, and the fact that boost and airflow arent the same thing, with airflow mods making the difference. And also that low boost and high airflow is key especially on pump gas. This is why people love strokers in daily drivers, including me. I'm tempted to build up a spare block into a little strocker for the 1g.
Kevin Jewer
Old 03-01-2005, 09:36 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Very nice explanation, Kev! In case anyone really wants to get into the complexities of turbocharging, go pick up the book Maximum Boost by Corky Bell. Just about everything you need to know (up to a point) is in that book.
And Kevin, I think you meant the 14b maxes out at ~30lbs/min, not 20lbs/min
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 03-01-2005, 07:26 PM
street_racer_00's Avatar
street_racer_00 street_racer_00 is offline
Whoooaaaa, brain overload of turbo information, you guys really know your shit...that helps out a lot guys, thanks....shit while I'm here, why is the 14b better than the T-25?
2000 Nissan Maxima SE, autotragic, sterling mist
My Max: Getting smoked by boosted cars since 2004
2004 AF award winner: longest time period w/o posting an actual street racing story
Originally Posted by CassiesMan
I got to see boobiues!
Old 03-01-2005, 09:47 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Kevin, I must say that must be the 50 bagillionth time you have written that same post with comparing boost, and airflow, and it still kicks ass.
Anyway, the 14b has a higher flow capacity, roughly 30 lbs/min like guitar said, and that info has been data logged many times, so it's a fact. As for the t-25, it's flow capacity is less then that of the 14b, thus it cannot create the same horsepower. Basically, that's what kevin was saying, well, part of it. (it can make more power at the same boost)
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 03-02-2005, 12:02 AM
AF - Advisor
Yes, I am a dumbass. I changed it to 30 lbs/min. T25 is about 22 if I rmember correctly. So when I say that a 14b is an awesome upgrade for a 2g, its onw obvious why. Almost 50% more airflow (power making) capaciy.
Thats the funniest thing I've read all day. I probably do repeat the same info all the time. If nothing else I guess it helps me remember it
Kevin Jewer
Old 03-02-2005, 03:52 AM
JoeWagon's Avatar
Banned
Simply, the 14b is bigger than the t25... there doesn't need to be much explanation for it. Bigger fans flow more air at the same RPM. Needs a more powerful motor though.. which in turbos is the time it takes to spool, lag.
Old 03-03-2005, 12:00 PM
AF - Advisor
Also the abaility to use more air. If you are maxing out the flow of the motor with one turbo, a bigger turbo can not move any more air. But typically a bigger turbo has a bigger hotside, which will allow a little more flow. I went from a 6h 20g to a 6h GT40 56 trim, and at 25 psi there was no difference in flow between the two
Kevin Jewer
