#16
Re: Alt help
i just wanted to know how to run 2 alt,
#17
Re: Re: Alt help
Running another alt, you are going to have to fabricate another bracket, and then find a belt that will fit. It would be a huge pain in the butt. That is my advice.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
#18
Re: Re: Alt help
To run it, all you have to do is run it in parallel. Positive to Positve, from one alt to the other, or to the fire wall where its all connected. Running to the fire wall would be better, because of the increased current draw might be too much for one wire going back. Does that make sense?
#19
Re: Alt help
yep, but what if i were to put it were my air condtioning pump is, im going to be taking that out any ways.
#20
Re: Alt help
Then the belt should be OK.
![]() When you get done, post some pics.
#21
Re: Alt help
ok so the power wire on both of the alt go in the same place same with the ground. Or does the power wire on the one go to the power wire on the other one and same with the ground. and what about the wire that come from my engine do i not need those for the second alt.
#22
Re: Alt help
Show some pics of what you got.
Both power wires get connected together, grounds go together. I have been running a single alt for so long, I cannot remember what the other wire is for, I'll get back with you on that. Are you sure the alt that you have is good? I't sounds like it may have some bad diodes. An alt normally has 3 sections that produce a charge, 2/3 can go bad, and it will still work, but it will only produce 1/3 of the current. So it will look like its working, but it really is not full functional. To check your alt, get a multimeter, turn the car on with all the accessories(radio, heart, de-froster, lights, etc) at a fast idle. Check the voltage across the battery, it should read 14v or a little more, if not your alt is not up to snuff.
#23
#24
Here is some what the finished product,
#25
Re: Alt help
Damn, do you enough power terminals
#26
Re: Alt help
o yes going to be running like 3200 Watts rms
