#16
Hi all,
OK, I did the tune up, new cap rotor wires and plugs, still happening. It's not a security Passlock problem because the symptoms don't match. I had to drive around in a snow storm recently for about an hour and the truck died while I was driving (first time that's ever happened). I pulled over and made a call for a ride, 15 minutes later the truck started and I drove home fine. It kind of ran rough for the first 15 seconds but then ran fine. My question right now is when I turn the key to ON and the fuel pump comes on, how loud should it be? Mine is LOUD! It's not bad sounding, not like a rock in a lawnmower sound but just loud like a vacuum cleaner is loud. Is that bad? People at work even notice it. I just thought that's how it's supposed to be. Also, does it sound like a loss Spark problem or a loss of fuel pressure? I’m going to buy a fuel pressure gauge this weekend and when it will not start again I’m going to check the fuel pressure. Thanks greatly for your help!!! Rick |
#17
Re: Weird intermittent starting problem...
My fuel pump is also very loud. My friends have commented on it. I can sometimes hear it while driving and it is a little annoying.
Have you put a code reader on this thing? That may help. Also, you said you were going to try the resistor bypass trick? Did you do that? |
#18
It's not nescesarily bad because it loud. If you have access to an oscilliscope, look at the waveform of the fuel pump. It should be very even. The waves are where the brushes in the pump contact 1 or 2 contacts on the rotor. If the pattern is eratic, your fuel pump is bad.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
#19
It finally happened again and I was able to get the code pulled at AutoZone.
It's Troublecode ODBII (Alpha) P Code. P1351 IDM Input Circuit Malfunction. About all I can find on the web is that IDM stands for Ignition Diagnostic Monitor Input Circuit. |
#20
Re: Re: Weird intermittent starting problem...
marc,
Just go to that page. At the bottom simply use Method A or B. I used (and recommend) Method A, which is a permanent bypass of the security code wire. You should be able to do the whole job in about an hour. You need something to measure resistance (an ohm meter), then you just need to go to Radio Shack and buy resistors to match (+/- 4%) the reading that you take. Solder the resistor in place as per instructions and you will have no more starting problems. Of course, this bypasses an important security feature, but I'd rather be able to start my car, LOL.
1968 427 Camaro SS 1998 Silverado K1500 2004 Corvette Coupe 2011 Chevy Avalanche ______________________ |
