Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 03-06-2005, 04:30 PM
noshun's Avatar
noshun noshun is offline
Re: Re: Cold air intakes
Originally Posted by ImSoYesterday
LD9 2200 engine, the vibrant intake I found doesn't hook up to the throttlebody, it hooks into the black box...
LD-9 = 2.4 twin cam not 2.2ohv!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 03-06-2005, 06:48 PM
liztic liztic is offline
it's a 2.2 rocjunkie
Old 03-06-2005, 10:04 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Parts needed:
1- 92-2000 Honda Civic intake
1- 94-2001 Honda Prelude Intake
1- 3 inch 45 degree rubber elbow ( 90 degree if 2200)
1- 3 inch cone filter
1- PCV breather filter
2- 3 inch hose clamps
Tools:
Slot screwdriver
Hacksaw
Metal file
8 mm socket
Sheet metal cutters
Step 1: Remove stock intake system. Refer to your shop manual to find instructions and tools needed for removing your stock intake system.
(There are 3 main parts to the stock intake system. You will remove the box that is located above the center of the engine. It has "2200" engraved on it. You will also remove the air filter housing and the 3 inch tube connecting these 2 boxes. Lastly you will remove the intake resonator. This piece is located inside of your fenderwell.)
Step 2: Remove your battery. If you did not remove your battery during the removal of your stock intake system, then now is the time to do it.
Step 3: There is a small 2.5 inch hole to the right of the battery tray. Use the sheet metal cutters to make the hole bigger. Try making the hole at least 3.5 inches wide. Later, you will slide the Prelude intake through this hole.
Step 4: Remove your driver side front tire. Remove the fenderwell liner. Use the 8mm socket to remove the small bolts holding the liner in place.
Step 5: Place the 3 inch rubber elbow over the throttle body opening. Place it at a 45 degree angle so that it faces the car's battery. Tighten the clamp and secure the elbow onto the throttle body opening. (If you have access to an aluminum elbow then use it.)
Step 6: The Civic intake has a 45 degree bend on one end. Attach this end to the rubber elbow and tighten the clamp until the intake is secured to the elbow. The Civic intake should be parallel with the car's bumper.
Step 7: Place the 3 inch clamp on the other end of the Civic intake and tighten the clamp.
Step 8: Use the hacksaw to cut off one of the 90 degree elbows off the Prelude intake. Use the metal file to grind off the excess metal on the intake elbow.
Step 9: Now flip the intake elbow and place one end in the 3 inch hose clamp. Tighten the clamp. Then place the remaining hose clamp on the other end of the intake elbow and tighten it down. You are about halfway done!
Step 10: Slide the remaining piece of the Prelude intake into the 3.5 inch hole that is next to the battery tray. Place the upper end of the Prelude intake into the hose clamp connected to the intake elbow. Tighten the clamp!
Step 11: The lower half of the Prelude intake should now be inside of your fenderwell. Reach into your fenderwell and place the cone filter on the end of the intake and tighten the clamp on the filter.
Step 12: Place the small PCV breather filter over the small hose that is sticking out of the valve cover. This should complete the installation.
(The Civic intake should have a hole to place your IAT sensor in. If it does not have one then you will have to drill a hole for it.)
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 03-06-2005, 10:06 PM
noshun's Avatar
HMMMM, where'd that come from?!?!?!
Old 03-06-2005, 10:22 PM
Lifted GMT-360!
Copy and pasting is a wonderful invention. Why waste my time typing it up if somone else already spent their own time wasting theirs...
www.ny-jbodies.org Biotch...
Old 03-08-2005, 12:56 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Damn CRJ, those are huge plug wires!
I like the leaf next to the battery, adds horsepower!
JK!
Are those pics of your car or were they copy/paste too?
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 03-08-2005, 04:08 PM
Lifted GMT-360!
^^^ They are from the same post i lifted that info from. My local car club's website. I have the 2200 ( LN4 ) with a butt load of mods waitin to be install when the weather breaks.
Old 06-21-2005, 10:26 PM
projectsleeper05 projectsleeper05 is offline
get a knn
Old 06-21-2005, 10:59 PM
noshun's Avatar
Or K&N. good luck though $$$ and an AEM is better!
Old 06-21-2005, 11:30 PM
Lifted GMT-360!
OMG.... he stirrs!
Old 06-21-2005, 11:45 PM
noshun's Avatar
peeps keep reviving thread so i HAVE to reply! how goes it Cody bwoi? I guess i could update my profile.
I'm lowered, got 17's subframe brace! BTW sportlines kill pro-kit! from experience only thing is sportlines mean regular trips to the chiroprocator!!
My car right now
Ran a 16.2 first time out ever, 35 degrees c with 70% humidity running the 17's. i'll drop that though.
you missed the ontario J-body bash though!
here's my pics though!
http://photobucket.com/albums/v336/n...o%20bash%2005/
most are friends. the red sunfire one of my best buddies. Gm Canada sponsored it and We had a public unveiling of the Grand Prix GXP 5.3 litre V8 with DOD and the G6 GTP coupe - 3900 ecotec v6! both very nice! and that gay HHR. oh and a fully modded ss s/c on 20" Konigs! was a great day!
Old 06-21-2005, 11:50 PM
alphalanos alphalanos is offline
first im not a cavi guy so dont bash me or anything but i have some advice anyway. this all depends on what you want to do with the car. big plans: dont buy anything until you do engine swap or SC. if you dont have big plans and just want a nice street ride, then get an AEM, K&N, or Injen then later get a quality exhaust, wheels, springs, shocks, etc. you need to have a plan for the best results.
96 EJ6. Future home of boosted B18C1.
Old 06-21-2005, 11:54 PM
noshun's Avatar
no reason you;ll get bashed you weren't all 'cavs suck' like people with imports weve dealt with in the past and you offered genuine advise. most people here though are building slwoly or just to a tight budget!
Old 06-21-2005, 11:57 PM
yep im def. in the 'building slowly' group lol
Old 06-22-2005, 09:34 PM
Lifted GMT-360!
mmmm.... Looks like some good ole fun you guys had dave. Not the best choice in the world for a meet. But anyways, I see you shyed away from the Tein's you wish that were someday made. I have ridden in a few cars that are really low and they are hard as a rock. I like my prokit which is stiff enough for me...heh! Rims are def nice and look killer man. My plan have been brought to a hault due to some thing causing wonder front wheel vibrations.. Only things left for me to replace are the cv shafts and tie rods. If that dosn't fix it, the car is up for sale.
