#16
Re: '00 Trans: 1-2 late, won't shift into R or 4
Don't discredit my advice.
Flush and fill could easily fix it. As said earlier it has never been serviced.
1995 Factory Blazer Service Manual for sale, PM if interested. |
#17
Re: Re: '00 Trans: 1-2 late, won't shift into R or 4
Given that: a) The sun shell issue with 4L60E's is very common, to the extent GM issued a TSB b) The trans went from perfectly fine to dysfunctional overnight c) My problems match those described in the TSB exactly d) You consistently give unsubstantiated advice that other people refute with experience e) I have yet to hear of ANYONE who had gears completely stop working, while others were fine, because of a clogged filter I think I'll skip the flush-n-fill and take it someplace to get the actual problem fixed. |
#18
Re: Re: Re: '00 Trans: 1-2 late, won't shift into R or 4
First of all, I wasn't talking to you in that statement. Second of all, insulting me when I was only trying to help is against the premise of this forum. Third, if you KNOW so much about this, why in hell did you ask the question in the first place? Go and fix it.
#19
Re: Re: Re: Re: '00 Trans: 1-2 late, won't shift into R or 4
For someone with 6000+ posts who trys to pass themself off as an "expert" I find it very peculiar you weren't aware of/didn't mention the TSB in the first place. |
#20
Re: Re: Re: Re: Re: '00 Trans: 1-2 late, won't shift into R or 4
Sorry if I don't know every single service bulletin on the planet about our trucks, and your inference that post count automatically means I have a knowledge about the every one of 1000s of service bulletins currently out there is not my problem. My post count comes from helping hundreds, maybe even 1000s of people with their s-series problems. If you have a problem with me helping people, that is not my concern. Last warning..... I will not tolerate the personal attacks when I was not rude to you.
#21
BlazerLT, since you say that a flush-and-fill has "fix their problem" in regard to others having transmission issues, has a flush-and-fill ever corrected a problem for someone who had the exact symptoms that this person has?
DJSteve, thanks for your information. Because you had mentioned this 'sun shell' that I never heard of, it made me do some research myself since I'm concerned about any transmission issues with my own Blazer. I learned something from your post. Thank-you. |
#22
But I have seen transmission slipping, and improper shifting caused by it. I am just offering a potential fix, I never said it WAS the fix, I am just offering advice. Nothing more. I was never rude nor did I say anyone else was wrong.
#23
For your information I am a GM trained mechanic, I also am a moderator on this board.
BlazerLT's suggestion of replacing the fluid does apply and it is a known fix for some trans issues. Yes GM has a bulletin on this problem but not all problem transmissions will be fixed by the bulletin. Just because you have the same problem with your trans doesn't mean this bulletin will fix your problem. If you read the bulletin it does not say "If you have this problem replace these parts". What it does say is to drop your trans pan and look for metal on the magnet, which would of been done if you follow BlazerLT's advice. As a GM dealer tech I see the people come in with bulletin in hand, telling me to do this bulletin to fix there problems. Many times the owners have failed to read the bulletin. Some times they don't have the problem and sometimes the bulletin doesn't apply to their trucks. And even sometimes they think they have the problem because they see a bulletin on it. At the bottom of every GM bulletin is written this! Quote:
Now as a moderator on AF I am appaled by some of the remarks that are posted here. I wouldn't of had a problem in handing out a ban for the insults posted. You guys have a very smart mod who wants to help you and who didn't want you banned for the insults. So stop the insults or I will be banning you using the AF guidelines the members agree to when they sign up.
Shop Foreman Buick Pontiac and GMC dealership ASE Master Tech ASE Advanced L1 GM Master tech Licensed Aviation mechanic |
#24
Wow such talk and to think I was out of town and missed these exchanges...
I really don't know why our opinions don't seem to hold equal value but in the spirit of trying to help DJSteve as I mentioned earlier..... The Flush and Fill is nice, but as I have learned first hand, a flush and fill which happened days earlier from my sun shell suffering metal fatique. I drove my vehicle in and the GM TECH knew exactly what it was....and he also showed me his diagnostic page, which I now own a set...on page 7-230 the only phrase it says for your symptoms is REPLACE THE SUN SHELL REACTTION assy. DJSTEVE, plze just have a dealer pull the tranny codes and confirm our suspicion.....I suggest this only because I had the same symptoms and sharing my experiences.... BTW - BlazerLT was diggin on me for my disregard for suggesting the above and discounting his full flush and fill....so don't take offense. It was me he was blazing not you.... Please let us know how your experiences go....I hope that it isn't the above issue but suspect it is. Just trying to save you an extra $200 bucks that's all.... |
#25
I thought I would post an update now that I was back on the road... the problem was caused by a broken reaction sun shell.
After being wholly unimpressed with the transmission shops in Ames I ended up taking it to a family-owned shop in Des Moines (~50 miles away). I told them I wanted it fixed right and such that towing a small trailer would not cause issues down the road. The Blazer has 119k on it, but I've only owned it long enough to put on 1k of that. The guy said the transmission had been rebuilt at some time in the past (non-recently), but that no updates were made and there were a lot of things done in a manner they wouldn't be comfortable with sending out of their shop. Other than the sun shell the vanes in the pump were also damaged (he thought possibly related to the previous service) and the seal between the trans and transfer case was leaking slightly. The final bill was $1850. $1052 was for parts. Their prices looked pretty comparable to what I had seen in earlier research online: Master kit - $292 Rebuilt torque converter - $230 Force Motor - $97 Band - $25 Input Sprag - $65 Shell - $42 Filter - $29 Fluid - $20 Valve Body kit - $60 Bushing kit - $19 Boost Valve - $40 Pump Kit - $60 Manifold - $64 Valve Body Accumulator - $10 |
#26
Excellent, glad you figured it out and are on the road.
#27
------------------------------------------------------------- - If anyone would like to see pictures of a broken sun shell, check out http://trustmymechanic.com/forum/vie...?p=21262#21262. They were posted by a GM master technician who works as a senior transmission rebuilder (his profile doesn't show up unless you're a member and are signed in). He immediately identified the sun shell and didn't cite any other conditions which would cause my problems. All the transmission shops I talked to who were helpful (willing to discuss the problem without charging a diagnostic fee) were familiar with this problem. It is not uncommon for 4L60E's. My understanding is that GM issued the TSB in 1999, but didn't update the part until 2003. So if you own a 1996-2003 GM product with this transmission make SURE you come to a complete stop before shifting from R to D (or vice versa) and pray yours doesn't fail while you own the vehicle. |
#28
My wife and I have a similar problem. We have a 2000 Blazer with 79,000 miles. Off the line it lags then it picks up speed gradually. The check engine light is on and it kinda revs high as if there's a lot of weight in the car. We took it to 3 shops. 2 said it was the transmission shift solenoid and Aamco said it was a broken shell and was gonna charge us $2200. We're gonna replace the solenoid first and give you an update!
#29
Unfortunately, welcome to the broken sunshell reaction club.... Good that it has been updated too.... |
#30
Thanks for the link and pictures. I admit I'm ignorant when it comes to transmissions, but information like this helps us learn. The pictures of a good and damaged sun shell was interesting, atleast to me.
Glad you got it resolved. |
