Old 02-18-2005, 02:40 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: New POS daily driver
Thats "traitor," FYI Shit, its still the same car... Just newer and a little bigger. I'm getting too old and fat for these little sport coupes.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-19-2005, 12:44 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
i hope your going to clean that thing....its not a bad car but i just hate all the rust on everything on the motor.
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 02-19-2005, 03:55 PM
AF - Advisor
Couldnt be bothered. My low 11 second car is just as dirty, and it doesn't slow me down Well, its a little cleaner because I pull the motor so often. Some of the dirt is bound to get knocked off.
In other news, I think I've finally got the hang of this double clutching. And I dont mean TF&F style. Didn't grind 3rd all day. The trick is to get rpms a little higher than I normally would, 4000 something, do the clutch action quickly, but put in it gear slowly. I guess the theory would be that at higher rpm, the rpm difference between gears is larger. So it falls during the shift, but not so much that its below where it would be in third at the current wheel speed (or intermediate shaft rpm). And putting it in gear slowly gives the synchro more time to accelerate/decelerate the input shaft and get a match (to the intermediate shaft). Sure beats going to 5k in 2nd and shifting straight to 4th anyway
Kevin Jewer
