Old 02-13-2005, 10:00 PM
JoshBarber JoshBarber is offline
Re: Re: oxygen sensors
Originally Posted by BlazerLT
Should be part of a preventative maintenance.
How many miles and what year is yours?
98 4.3L LT 4x4
104k miles.
I was told there were 4. But they're not cheap. I think like $200 for all four. Do you reccommend I wait until I have a code, or symptoms? Or replace them now. Keep in mind I have little money. Should I stick with just the fronts if so?
Old 02-13-2005, 10:12 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Re: oxygen sensors
Originally Posted by JoshBarber
98 4.3L LT 4x4
104k miles.
You are getting in the range where you should start thinking about replacing at least the three before the cat. The one after the cat is not so important seeing it only monitors the cat for efficiency.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-14-2005, 07:44 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: oxygen sensors
My '95 has only one pre-cat sensor as well. Seems that there was a change over to full OBD-II systems in the middle of the production run and we start seeing pre & post calayst sensors appearing...then the massive 4 sensor configuration in '96 onward.
Old 02-14-2005, 08:06 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Some 95's (like mine) have 3, so have 2 (any with 3 or 2 have the ECM under the hood for 1st revision of ODBII) 1 sensor will be ODBI.5. Also same with 96 to current. Some have 3 some have 4, no pattern I can discern on why some 3 or 4...
Old 02-14-2005, 11:57 AM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
I have 158000 on mine and haven't changed them. I continue to get 18-22 mpg. No codes or issues....I suspect that I will begin to see either a decline in Mpg or SES eventually.
Dealer techs tell me..."if it aint broke don't fix it".....worst will be sucky gas mileage, and SES.
The risk vs cost says to me...says wait.....it's not a castrophe if you through a code....
OK I'm ducking now fire away haha !!!
Old 02-14-2005, 08:59 PM
BlazerLT's Avatar
AF -Advisor
3? 1 or 2 only.
Old 02-14-2005, 09:03 PM
rlith's Avatar
Re: oxygen sensors
I can most definatly say I have 3, and 3 other 95's that I have worked on have 3... Hell, I didn't just spend 150 bux on 02 sensors last weekend for nothing...
Old 02-14-2005, 09:22 PM
Fireplug Fireplug is offline
Re: oxygen sensors
The 1995 Blazer is a half breed. Its working on a basic obd2 system. Had to have special adapters for the GM Tech Tool to work on it. It was a big pain in the butt
Old 02-14-2005, 09:24 PM
rlith's Avatar
Actually the flash I recently got at the dealer made mine totally ODBII compliant instead of first revision...(See my other thread on the subject )
Old 02-14-2005, 10:08 PM
BlazerLT's Avatar
AF -Advisor
Where are they located?
Old 02-14-2005, 10:10 PM
rlith's Avatar
Re: oxygen sensors
On mine, one on the down pipe just after the flange, one just before the cat, one just after, none on the driverside down...
Old 02-14-2005, 10:15 PM
BlazerLT's Avatar
AF -Advisor
Re: oxygen sensors
Ah, I have one before and one after the cat only.
Guess I got lucky.
Simpler, the better.
Old 02-16-2005, 02:15 AM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Re: oxygen sensors
Back open for business (after a bit of cleaning). Defient, if you post anything else in this thread bitch towards BlazerLT, I will delete the post and ban you. The issue is over and done with. End of discussion.
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 02-16-2005, 08:40 PM
westsider westsider is offline
I have a 1996 Blazer and I would also like to change the o2 sensors. but I just wanted to know if you really need that special socket to get them off. Which kind of o2 sensors did you guys use? Is there any difference? I havent checked how many o2 sensors I have but should I only change the ones before the converter. Thanks for any help
Old 02-17-2005, 06:26 AM
rlith's Avatar
Re: oxygen sensors
Simply use a 7/8th box wrench (spray with some pb blaster an hour or more before taking them off) If you can avoid burning yourself on the pipe, run the car to operating temp so it makes it easier (obviously turn the car off when you go under it).... As far as sensors go, Plain bosch works just fine (bosch makes the OEM sensors as well)... You can get them at any autoparts stores.
