Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-26-2005, 08:29 PM
df2000 df2000 is offline
Send a message via AIM to df2000 Send a message via Yahoo to df2000
Re: Re: Tried everything ENGINE TICKS LOUDER
Anybody care to try Auto-RX from www.auto-rx.com. It is kind of pricey
at $25 a bottle and you need 2 usually, but seems like right stuff for this job. Follow directions on site.
Old 02-26-2005, 11:03 PM
Cat Fuzz Cat Fuzz is offline
Originally Posted by amigo-2k
Make sure you change your oil ASAP, after using Sea Foam for the first time.
ASAP meaning the same day. You don't want to run your engine above idle with Sea Foam in it. Makes the oil the about consistency of water.
BTW, no one thinks he might have a bad t-belt tensioner?
Old 02-28-2005, 05:20 PM
Izu3.2 Izu3.2 is offline
I Had The Same Sound, I Changed The V-c Gaskets And Found That (2)plugs Were Under Oil 1/2 Way Up The Tubes. I Replaced The Grommets And I Have Put About 450 Miles Since The Without A Peep. Grommets Were 10 Bucks Apiece But Worth It. Oil Pressure Is 30 Warm.
