| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
#16
Re: new subs??????
PS...
SPL XXX SX Avalanche SQ XXX Avalanche SX IMO |
#17
Re: new subs??????
has anyone heard the avalanches before?
#18
Re: new subs??????
they are from ascendant audio
Ascendantaudio.com watch this vid and tell me you dont want one This Vid is good like sex on a sunday morning |
#19
Re: new subs??????
SX is louder than XXX. and this i know for sure cause its been tested. i think even the guys at RE say that its like over 1db louder at every freq. and i think its more than that at a certain freq... cant remember what i read but im pretty sure that im right that the SX is louder..
and as far as the SQ you might be right but i think they would be close enough to call a tie
1996 Explorer 4.0 V6 4x4 Sold all my shit. waiting for more money |
#20
Re: new subs??????
sorry, you are right, i was thinking SE.
once agian tell me you dont want one!!! http://www.realmofexcursion.com/vide...totype12.1.wmv |
#21
Re: Re: new subs??????
4 would be nice |
#22
Re: new subs??????
4 would blow your car appart...just to let you know
an xxx15 is capeable of ~145dB tops in a ported enclosure. it has 32mm one way xmax. that woofer has 60mm+ one way xmax. does that mean it is capeable of 290dB? no. but that does mean it is capeable of probably into the 150-155dB range. 4 would be compeating with the 9 15's SPL monster class dragers are using. and it would take significantly less wattage. this is basiclaly a scaled down parthenon with surrond and basket. i like how someone over on soundillusions said it. "and its ONLY moving 4-5 inches P2P there. we still have about another 3/4 to go" |
#23
Re: new subs??????
what the hell?? whats up with that vid? the surround looks like ass when its moving like that. am i looking at the vid right or am i missing smoethin here..
cause ive seen pics of this sub moving like that and the surround was totally fine when it was moving like 4.25 in. p2p.
#24
Re: new subs??????
i dunno, but i wouldnt expect a surround capeable of 6" P2P to look ant better.
#25
sarcasm.....but thanks for the info i think i have narrows it to two avalanche 15's or two RE SX's now i just have to come up with the funds for them Last edited by oraxid24124; 02-13-2005 at 07:37 PM. |
#26
Re: new subs??????
i still think you should get one of thoes bad boys once they are out. it should be less than $1000 or right around there $1700 tops. its XBL^2 which means awsome SQ and with 1000-2000w it would be at least 3-6dB louder than two SX's
#27
Re: new subs??????
Sorry, i hate to tell you CBfryman...but in facts AND logic you could not be farther from the truth. You missed in almost every aspect, when I have more time I'll come back and let you guys know a little of what's up, I'm not allowed to open my mouth too much tho
![]() NG |
#28
Re: new subs??????
LOL you crack me up man 2 SX's off the same power will murder any single 15 I can think off CONE AREA. And SPL has VERY LITTLE to do with your subs. Those new ones will not be hitting 150's or anywhere close in a daily setup. More like 145 TOPS for the 15 and that's in a DAMN good install fully powered. and an XXX15 does not do a 145 in most installs and yes it can be louder then a 145 I'm sure someone could EASILY crank a 150 outa one in an SPL setup. Its all in the install.
2002 Ford Explorer Limited D31 yellow top Kenwood DDX-7017 2 Ascendant Audio Avalanche 18's 13 cuft NET ported box tuned to 27hz Autotek Mean Machine MX3000.1 Ascendant Audio Arco component set Orion 275SX (Mids) PPI Art Series A200 (tweets) Poly Mids for rear fill to come soon. |
#29
Putting all the stuff together just to clear things up...this is in no means meant to belittle anyone, just wanted to clear up some misconceptions.
4 wouldn't blow a car apart, it would sound good and be really loud (if properly powered and installed). You can NEVER say the absolute maximum decibels of a subwoofer. Many people have hit over 150dB's with a XXX in an SPL, I'll being trying to do so myself soon. These subs are in NO WAY "SPL monsters", they are XBL^2 enabled, and juat have a shitload of throw so they will have great output! If someone uses them in an SPL install, they would be dumb...b/c of many reason which i could elaborate on more if asked to do so. In no way is it similar to the parthenon. Also the "someone" who said it over at siN was David, part (?) owner of RE. Quote:
It will need 2kw+ from what has been said. And again, there's NO way to say how much louder it will be than any other driver...keep in mind the SX is louder than the current XXX, 1.4dB's louder to be exact in David's testing. So, there's TONS of things that will be happening with NUMEROUS companies in the next 6 months. Be looking out especially in the next 2-3 months...you'll be happy and surprised! peace NG |
#30
Re: new subs??????
It 2 XXX 15's can make door hinges crack in more SPL oriented set ups...id hate to see what 4 of thoes would do. Maybe like Scottie's, what was it 9 brahma's, cracking his door frame completely in half. (BTW did he switch to XXX's now?) I was just giving a roudn about estimate of what your aveage guy can extract form the XXX. 145, or there bouts is what your average guy gets from an XXX. in SQL set ups ive seen 135-140. Im hoping 140 when i want it to go that far from my 18 once i get it and get The Beast. im hoping 130-135 with the Hifonics amp. i may buy two instead of the beast and wire them master/slave to get a sapposed 3600w but probably sitting more near 2800-2900.
Surface area*excursion is what matters in SPL, not just surface area. someone said 5 3/4 is what thoes surrounds are capeable of doing. which is right about where the motor on it stops pushing. which dimpleing isnt a bad thing but it isnt good either. it may effect sound a TAD if it isnt very loud but not audiable at the levles most surrounds start dimpleing. mostly it is just ugly. plus that is a pretty old video, they may have done some tweaking to that surroud after that vid. of course JL never dimples....:cough: but i will tell you this, i wouldnt want to sit in a car with 4 of thoes even 12's or 10's. |
