Old 02-10-2005, 11:51 AM
Igovert500's Avatar
blue + red light magnet
Re: 3000GT SL Questions
Personally, I think the 3000gt should have come with 13G turbos and 450cc injectors stock...even if they had turned the boost down (like they did on ours...9 and 12 respectively)
It would have given just that extra edge of potential. Just my opinion.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-10-2005, 01:24 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
didn't the GTO in japan come with 13Gs? of course, with their gentleman's agreement over there, they come factory tuned to no more than 280 hp. of course, with that setup, mod potential would have been much greater than our 9b setup in the states. even if they threw in 13g and bigger injectors, it wouldn't have upped the price by more than a few thousand. i agree igovert.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-10-2005, 04:06 PM
3KSL95's Avatar
3KSL95 3KSL95 is offline
Send a message via AIM to 3KSL95
I think the SL should have been a single turbo, and rated at about 250 hp that would have been nice.
1995 3000GT SL (RED)
My mods:
Custom true dual exhaust with x pipe
K&N FIPK
17 inch forged aluminum billet rims from WELD EVO
Old 02-11-2005, 11:38 AM
Old and good Old and good is offline
Send a message via MSN to Old and good
hehe my friend just put in 1000cc injectors and a supra gas pump and changed the turbos to 16.5psi the injectors are to powerfull and drown the sparkplugs.
i have been wondering for a while what are the pros and cons of a V6 vs a inline engine?
Old 02-11-2005, 04:05 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: 3000GT SL Questions
Nope, absolutely no GTO came with 13g turbos. The only ones to come with 13gs were some of the Euro spec 3k's. Also thats not 280 hp its 280ps. Thats metric hp. They are the same hp as American spec 3ks. And people are talking about 13g's like they are some super turbo. They are the same size as a 9b, they just hold more boost to redline. If someone has the turbos in the car you would not be able to tell the difference between 9b's and 13g's unless you pulled them and took it apart. I do however agree that Mitsu should have used 450's as stock injectors. I mean they gave them to DSM's why not 3s's?
Also talking about rarity, 3s's are rare enough but there were more 3s's made in one year than the total run of MKIV Supras. Thats why people hardly ever see Supra's. Its not that they are not popular.
Toyota Engineering has always been known to be superior. The only company even close in regular everyday cars is Honda engineering.
Old 02-11-2005, 04:45 PM
Getsum3kgtsl Getsum3kgtsl is offline
What is the MKIV supra? Are they the twin turbo? I have only seen two, my (ex) step grand father (he was toyota dealer) and a kid here that wanted to race me.
Old 02-11-2005, 05:59 PM
Stealthee's Avatar
MKIV= Mark 4= 4th generation Supra= 93-98 Supra
Old 02-11-2005, 09:13 PM
i know that toyota is known for its reliability but that does not make the car superior it only means that it brakes more seldom down.... the 3L engines are both producing the same hp..... if i wuld be offered a new supra or a new VR4 and there wuld be as many supras on the road as the 3s's im fairly sure that i wuld take the VR4 as it has so much more to offer especialy in luxury equipment
Old 02-12-2005, 10:58 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
your buddy need an msd ignition or somethin...and I know one thing about V vs. I..the inline is smoother because it has less opposing forces...less opposing forces = "easier power"...just in case u dont know what i mean...the opposing forces would be the pistons moving in different directions. In a v-style engine they can't exactly cancel each other's movements out...in an inline they can, one goes up the other goes down...same with a boxer engine...which is why they run smoother.
Old 02-12-2005, 11:47 AM
so what good can come from a V style engine. more torque?
Old 02-12-2005, 07:19 PM
Linebckr49's Avatar
simple design, can easily fit into small spaces. transversely mounted in the 3/S so that it can be integrated into different chassis (Galant).
93 3000GT base
Old 02-12-2005, 08:00 PM
Yeah there's no advantages of HP or Torque...it's pretty much for balance or space.
Old 02-12-2005, 08:32 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Pschh who needs balance.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-13-2005, 08:28 AM
yeah who needs balance. like themy old firebird man that was fun..... if i reved the engine up the whol chasis went sideways and gave you a feel that you have a real monster under the hood. i tryed it on my 3s but it only does it a litle bit and it not noticeable from the outside :S
Old 02-13-2005, 10:40 AM
Linebckr49's Avatar
who needs balance? maybe the crankshaft! oh wait, we've got the harmonic balancer built into the crank pulley...that is IF you haven't upgraded to a lightened or even underdrive pulley! unless a new one has come to the aftermarket, all aftermarket crank pulleys made lack the harmonic balancer.
so engine vibration, balance, V6 design, harmonic balancer...go figure. i wonder what design best resists vibration: inline, boxster, v?
93 3000GT base
