Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 02-10-2005, 04:40 PM
caryhson1 caryhson1 is offline
Send a message via AIM to caryhson1
no i checked the pads. i even tried putting new ones on and that worked for about a week before i noticed it again..i dont understand because it does it even when i am not braking.....i though maybe it was the caliper
think i should take the rotors off and get them rotated?
Old 02-10-2005, 05:31 PM
andrewken's Avatar
andrewken andrewken is offline
Re: Odometer Check
interesting. My 01 spyder gt 5 speed is making a high pitched reer reer siren type of noise. It gets worse with speed. Sometimes it there, sometimes its not. Could something like this be my problem? It sounds like its coming from the front passenger side and the car is running fine except for noise.
Old 02-10-2005, 06:02 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Odometer Check
may be a bearing, my friend told me my rear right rotor was warped so i took it to the dealership (warranty work for the rotor) and they said it was my bearing, the noise is gone, i may still have to do the rotor though, becuase it looked a little warped to me
but it was a similar squeeky like it was something rotating
Don't act like you don't love it.
503/2000
Old 02-10-2005, 10:50 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
It might be the wear indicator. Check your pad and make sure the indicator isnt pushed against the rotor. Also, if this is the case make sure you didnt groove your rotor...i dont think it really makes a difference, other than the fact that there will be a big streak on it. If not then id go with the bearing.
Old 02-11-2005, 05:45 AM
FairyDust's Avatar
FairyDust FairyDust is offline
24yrs old, Black 01 GT with 42,800 miles on my car. So far no problems or damage or anything. I personally have put 10,000 miles on it, bought in July with 32,000 on it.
Old 02-11-2005, 11:17 AM
FIGG's Avatar
FIGG FIGG is offline
Send a message via AIM to FIGG
Re: Odometer Check
02 ECLIPSE...56000 Miles..all mine but 3...Bought in dec of 01
Old 02-11-2005, 01:04 PM
dickswhip00gs dickswhip00gs is offline
Re: Odometer Check
when i first bought my 'clipse, the front end would squeak and shake violently, even after alighnments and balances. i brought it back to the jaguar dealership, and when they tore it apart,they had found that the hubs were worn. sorta fked up and dangerous. they replaced them under their 3 month warranty.
Old 02-11-2005, 01:05 PM
Re: Odometer Check
also- what about yer e-brake. maybe the adjustment or something?
Old 02-11-2005, 02:10 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: Re: Odometer Check
just a question... the hubs are the piece that the back of the rotors sit against?
Old 02-11-2005, 04:58 PM
Re: Odometer Check
naw, i believe you may be reefering to the backing plate. hubs are the finely honed shafts that bearing ride on. theres a bolt/threads on the end and usually a pin to hold them bad boys on there.
also i forgot to mention my u-joints were replaced as well.
