#16
Re: 97 blazer heat blows cold
First, yes, that is the thread I was referring to.
Second, Apparently you didn't read it. ONE person said that their Blazer ran a little bit warmer than the pic shows. |
#17
Where is the temp sensor located? What temp would the coolant be after going through the radiator? Obviously it won't be the same as the temp at the t-stat, especially this time of year. The lower temp coolant coming from the radiator heats back up to 195 degrees by the time it reaches the t-stat before going into the radiator again so it is cooler as it runs through the engine.
Incidently, I just changed the t-stat because the previous one (another 195 degree) was staying open and the vehicle wasn't reaching the proper operating temp. |
#19
The sending unit is on the drivers side head just above the #3 and #5 spark plugs.
The temp after going through the radiator depends on lots of things. Airflow, air temp, antifreeze concentration...... I'm not sure if you were asking or not, but this is how the cooling system works: The engine warms up, the thermostat opens, when it opens it allows the coolant to circulate through the radiator. The coolant exits the engine through the thermostat (not enters as some people believe) as the warm coolant exits the cooler antifreeze enters and circulates through the engine and exits through the thermostat warmer than it entered. (how much warmer depends on how cool it was when it entered, how hot the engine is and few other things) It then enters the radiator and the cycle continues, the more it circulates, the more the engine cools, until it gets to the point that the coolant exiting the engine is so cool that it no longer holds the thermostat open. The thermostat then begins to close, as it does it restricts the flow of cool antifreeze in to the engine. This causes the engine to warm back up, opening the thermostat back up a little and letting it cool back down. This process is repeated over and over as the engine runs to maintain a fairly constant temperature. |
#20
Thanks for the sensor location info.
I wasn't actually asking how the cooling system works, just stating that the coolant temp will be different throughout the engine. As for the reference to the other thread, I was just pointing out the discrepancy between what was "normal temp" there and what was said here. |
#21
Re: Re: 97 blazer heat blows cold
To test it: 1. Remove the sending unit from the engine and clip ohmmeter leads to the sending unit body and the terminal. Place the sending unit in a pan of water on the stove, with a cooking thermometer in the water. On a cold (50-80 degrees F) sender, the resistence should be 5,700 to 2,200 ohms. When it has warmed up to operating temperature (170 to 200 degrees F) the resistence should drop to 200-300 ohms. You may also want to test the wire and gauge, to do this, just ground the wire to the sending unit housing, when you turn the key on, the gauge should go all the way up. |
#22
We have a lot more experience than YOU do so how about you stop telling him that we are wrong. If the temperature reading is only going one step over 1/4, you cannot sit there and tell him that it is ok. You also forgot to tell him that we just fixed a guys truck on this forum with THE EXACT SAME READING ON THE TEMP GAUGE. AND GUESS WHAT, IT WAS THE THERMOSTAT!!!
1995 Factory Blazer Service Manual for sale, PM if interested. |
#23
Re: Re: Re: 97 blazer heat blows cold
Re: Re: Re: Re: 97 blazer heat blows cold
#25
BlazerLT, check that other thread I referenced. Why did you say that it was reading normal and now you say that it's running cold? Make up your mind.
#26
Thermostats can stick partially open and if it it only barely getting up to one tick over a 1/4, you bet your ass his stat is partially stuck open.
#27
So if mine looks like the one in the pic, is it normal or running cold? I apologize for stepping on toes (or in this case, kicking shins), but it seemed like you were contradicting yourself with the two different "normal" temps. Since I have already replaced the t-stat and the one that I originally had was giving me the same reading, should I replace it again? Are there faulty t-stats from certain manufacturers like that recurring problem with the AC Delco rad cap?
#28
After a good warm up, it should be one or two ticks to the left of the half mark depending on air temperature.
#29
i flushed out my heater core only just to see if it did anything, i just disconnected the hoses and blew it out, connected everything back up and i have real good heat now. lets see how it lasts
#30
I heard that air in the system from a leak might cause this problem. Idle the engine with the radiator cap off for about 10 minutes should get the air out. Make sure the heat is on full when you do this, to include the heater core.
Again, this is only what a heard once. Worked for me at the time. |
