Old 03-29-2005, 12:03 PM
borninski borninski is offline
tune up
I work at a State Vehicle Inspeciton station in Texas. I recently bought an '87 S10 Blazer 2.8 V6 2dr 2wd auto and I did did a sample state inspection on it to see how it was running. Everything was perfect because the previous owner tuned it up recently and replaced the EGR system. Therefore, the HC, CO, and NOx readings are lower than most vehicles I inspect.
As you stated, your HC reading is basically an indicator of how much unburned fuel you are simply blowing right out of your tailpipe as a result of incomplete combustion. For example, I am willing to wager that your gas mileage on your S10 sucks bigtime.
Simple fix: do a complete tune-up (this is what we tell all people who fail specifically on high HC and CO readings). It will obviously make your engine run better and cause your emissions readings to go way down, but it should also give you at least a little boost in fuel economy since you'll be wasting a lot less fuel than you previously were.
Get a new air filter, new spark plug wires, spark plugs, distributor cap, and distributor rotor.
(Timing could also be a problem if the above recommendations are not enough...although I would definitely get the complete tune-up done first and foremost.)
Old 03-29-2005, 12:41 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: S10 having trouble passing Smog
Big vote for retarded timing.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-29-2005, 04:20 PM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Hey just move to kansas. They just make sure you have an engine under the hood. They dont check anything. sorry i cant help, anyways good luck dude.
Old 03-29-2005, 08:51 PM
96Civ's Avatar
96Civ 96Civ is offline
Actually the car gets excellent gas mileage. I spend about $100 a month on gas, and that is about a 30 mile commute every day.
Updates: I took the car to a smog diagnostic and they basicly said my carb is most likely the problem AS WELL AS the EGR (It was full of gas) I ordered a carb rebuilding kit and I am working on fixing the EGR and PCV.
Old 03-29-2005, 09:23 PM
16th hippy 16th hippy is offline
not sure what state that is for, but i am an inspector in texas, in an emissions county. That is the highest HC count i have EVER seen(and i've seen some pretty high ones)....definately running rich at idle. If your EGR is full of gas, then u definately have something leaking more gas into the engine than required at idle, hence the carb needing attention(rebuild or whatever is needed)
@borninski: ESP machines SUCK!
"EDIT" Ya know, someday when i get more time i might read the whole thread all the way through....until then please bear with me guys...lol
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
