Old 08-30-2005, 01:18 PM
misfitt006 misfitt006 is offline
Send a message via Yahoo to misfitt006
Hey everybody. Sorry to bump an old thread back up but I just came across this message board searching for a lift kit for my '02 Z-71. I am new to the truck world as this is my first pick-up. All I am looking to do is put some 33's on it. I've been told that I can't do it with a stock suspension because the front end is too low and I won't have room to turn the wheels with 33's. Will installing these ford keys give the the room to do this or am I still going to be required to lift it up some to get the clearance I need for turning? If these won't work for what I want them for, does anybody know of any other options that I can use without spending $1,500 to lift my truck?
Old 08-30-2005, 03:40 PM
sledneck781 sledneck781 is offline
Send a message via AIM to sledneck781
Re: 2002 Leveling Kit.
Yeah i think it should give u enough, look at the measurements i gave in the forum thread earlier on. I have seen it with 35s and they rubbed only a little. 33 should be fine. Goodluck
2003 Silverado 1500 Z71 Ext Cab 5.3L Arrival Blue
1997 Arctic Cat Ext 600 triple.....catch my roost
Old 09-22-2005, 10:32 AM
Originally Posted by norwood
Basically a leveling kit for torsion bars consists of torsion keys with different indexing or "clocking". This allows for a much higher adjustment than the stock would allow. Such as the Ford keys I installed on my '99 Silverado. All that being said, understand that you are still "cranking" up your torsion bars. Thats what leveling is. I raised my Silvey about an inch and a half or so. So far every thing has been fine.
BTW the leveling kits you may see on ebay are nothing more than these different indexed keys and I've seen them for $70-$80 bucks to almost $200!!! What a rip-off!!
The place to get them is http://www.fordpartsonline.com/
Use part#XL3Z5B328CA about $18 bucks ea. if I remember right
The article that tells all about this: http://www.fullsizechevy.com/fscu/fordkeys.shtml
Hey Norwood I hate to bump this old thread back up but I'm looking to buy these and install them within the next 2 weeks and looked at the website that you gave and I have a question. When i did a search with the part number it came up with about 4 parts and I'm not sure which ones I need. It also doesnt specify if it is the driver or passenger side. I know that they can only be installed one way and I was wondering if it is the same part on both sides or is it two different parts. I called my local Ford dealer and they want over $30 each for them so I'll be getting them online for $19....suckers Thanks in advance
Old 09-22-2005, 10:34 AM
By the way I've got an '02 Xcab 1500 Z-71 4wd
Old 09-22-2005, 03:29 PM
fire24resque's Avatar
fire24resque fire24resque is offline
How many turns can you crank your torsion bars before it becomes unsafe? I cranked mine 6 full turns about a year and a half ago, my truck isn't totally level, probably about an inch or so to go, but I'm afraid to do anymore. I'm not really interested in getting the torsion bar adjuster keys to level it out, just wondering how far is safe to crank on them.
Old 09-22-2005, 11:21 PM
norwood's Avatar
norwood norwood is offline
Re: Re: 2002 Leveling Kit.
I'm not sure what you came up with. When you go to that Ford parts site, you need to enter a vehicle type. I just enter a 1999 F-150. Then the torsion key part #........
TORSION BAR ADJUSTER, F150-250 - 4WD 97-04 $25.53 $0.00 $19.15
Front suspension - Wheel bearings - Torsion bar adjuster
Is what should come up. Same part left or right. You will need 2. They will fit an '02
'99 Silverado LS
stock 5.3L
clear corner lights
vent shades
Ford torsion keys in front
Tuff Country Add-A-Leaf
Old 09-22-2005, 11:33 PM
norwood's Avatar
I don't know if it's really a matter of "unsafe" or not but as with most anything, you usually don't want to go to the max. Worst case is to raise it so high that the suspension is topped out all the time. Not good.
Probably not enough adjustment in the stock set-up to really do that. But if you're satisfied with the way it looks now, I wouldn't go any higher. How are your tires wearing? Very important to get alignment checked/adjusted after messing with the torsion adjustment.
'99 Silverado LS
stock 5.3L
clear corner lights
vent shades
Old 09-22-2005, 11:38 PM
Re: Re: Re: 2002 Leveling Kit.
Hey thanks a lot for the info. I just went to the site and did a search for the part number without putting in a vehicle. Do you happen to remember what the shipping charge was on these? I went to order tham today and it would not tell me what the shipping charge was until after the order was completed and I thought that was a little sketchy so I was going to shop around a little bit. I'll probaby order it from the site anyway I just don't like authorizing someone to charge my card until I know exactly how much they'll be charging....call me crazy lol
Old 09-23-2005, 02:52 PM
I guess I'm ok with where it sits now. Like I said I cranked them 6 full turns each. About two days later I took it and had a full alignment done. Tires are wearing fine. I guess I'll leave it alone before I cause problems!! Thanks.
Old 09-23-2005, 03:58 PM
norwood's Avatar
Re: Re: Re: Re: 2002 Leveling Kit.
No, I really don't remember how much shipping was. It wasn't anything outragous or out of line because I'm pretty much a cheap bastard.
'99 Silverado LS
stock 5.3L
clear corner lights
vent shades
Old 09-23-2005, 04:56 PM
redneck45 redneck45 is offline
I only got 3 turns on one side and 5 turns on the other before the bolts bottomed out (it was not level from the factory) on my '99 Z71. Put add-a-leafs in the rear and had it aligned. Now it sits like norwood's truck. Rides just fine. Next is 285's and bilstiens. Original reason was cause it would sit low
with my boat attached, so after the add-a-leafs the rear was way up. Much better looking and haulin truck than before. The 1/2 ton chevys are very weak in the rear if you put any kind of load on them.
