Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-10-2006, 08:04 AM
bransonbluffs bransonbluffs is offline
Re: Re: 99 Suburban Power Steering Proble
Originally Posted by 777stickman
Is this on your "new" Sub? Disconnecting the plug at the pump will "definitely" affect the steering as it will make it easier at all speeds. This is something you should only do to see if the problem is mechanical or electrical. If the problem goes away, replace the steering sensor ASAP and reconnect the pump wiring. The steering sensor is a 90% cure for this problem.
Same symptoms on my 98 with 122K, Steering Sensor fixed the problem, Thanks
