Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 02-02-2005, 04:08 AM
Layla's Keeper's Avatar
Layla's Keeper Layla's Keeper is offline
Supermodified
To anyone who has any doubts about how good a three-link solid axle rear suspension is on track, simply consider this: The bog standard rear suspension for SCCA GT5-1 IS a three-link solid rear.
Next time one of those tube chassis wunderkind 240SX's or Camaros is in the pits at a regional track-day, take a look at the rear suspension and you'll see it's the case. A solid axle suspension with good geometry will always outdo an independent suspension with mediocre geometry.
And most folks forget the reason independent is used in road cars. It's not cheaper to manufacture or inherently more reliable, but it's easier to make a car that handles well enough and is comfortable. Most of the Camaro's complaints centered around a harsh ride that was caused by going too far to a rigid suspension for good handling.
The new Mustang GT handles just fine for ANY car in its price range and isn't handicapped with its live rear axle. There's a shade of understeer at the corner entrance (that could be cured by some non-all season tires) and a little bit of oversteer at corner exit that's easy to catch. No histronics. No axle tramp. No snap oversteer, just an easy to gather up coupe that'll run with the rest of 'em.
Proud Owner/Operator of Haven Raceway and Hobby!
Old 02-04-2005, 01:09 AM
CrzyMR2T CrzyMR2T is offline
Re: How's the new Stang's Handling compared to
the irs wasnt only designed because of its good handling/ride combination, but also because its better for handling itself. i wouldnt say the solid rear axle will always out handle a regular irs system, if all things equal but the suspension, irs vs solid, the irs will always, or more than likely out handle the solid axle car. the irs design would have to be pretty bad for the solid axle to out handle it. lets face it, roads arent gonna be completely flat, even on race tracks. also, you want the suspension components to be light as possible, so the wheel can move up and down quicker through bumps, and dips, basically to keep the tires on contact with the road. the solid axle is a heavy suspension system, so theres a lot of unsprung weight. to compensate for all this unsprung weight, more damping is used, but too much damping isnt good, cause it makes the wheel move up and down slower, which is what happens to a lot of solid axle cars. thats why you want the suspension components to be as light as possible. anyway, a solid rear axle car can still handle good, but not as good as an irs system.
mr2 club website m3
www.mr2oc.com
Old 02-04-2005, 01:32 AM
Supermodified
Eheh, nice try junior. Live axle suspension setups are actually LIGHTER than independent. Fewer components, remember?
Your statements on damping are theoretically correct but hinge entirely on the geometry of the control arms. Take into account a leaf-sprung live axle rear suspension. The travel is determined by the length of the primary leaf measured against the height of the primary mounts. (mount height = bound length, primary leaf length = rebound length). The roll of the suspension is determined by how far apart the leaves are mounted.
In a car such as my MGB, which has short primary leaves and wide leaf spacing, there is very little roll or rebound, which allows for softer springs which then allow for better handling over a rougher surface.
In control arm/coil spring setups determining the geometry is much more complex, but equally determines the basic handling characteristics. You go over damping and unsprung weight like they're the most critical things. I've designed ground up suspensions, and I'll tell you this, it's all about the geometry. EVERYTHING else is totally unimportant.
Old 02-04-2005, 02:03 AM
it has more parts, but those parts are smaller and lighter. the live axle suspension is still heavier, the parts that have to move up and down are actually heavier compared to the irs system. the drive shaft and the gears have to move with it, so it actually weighs more, even the beam itself is considered heavy. even if you spread the leaf springs further apart, all that weight is still gonna move with it, even if it leans from one side to the other, its still part of the suspension. the suspension isnt going to only move from one side to the other, its gonna go straight up and down too, im not sure what your trying to say. another thing is that the leaf springs on solid axles are relatively heavy compared to modern suspension. also if you wanna talk about geometry, since its not independent, the wheels are effected by each other. when one wheel hits a bump or a dip, guess what happens to the loaded side of the wheel when turning? lets say the car hit an apex? im sure you know what i mean. in suspension design, geometry matters, and so does weight, just like a smaller car will change directions easier than a heavier one, with everything else equal. im sure theres a reason why f1 cars, and high end sports cars go indep.
mr2 club website m3
www.mr2oc.com
Old 02-04-2005, 05:22 AM
Supermodified
You assume far FAR too much.
A suspension's concept - be it live axle or independent - is purely PURELY theory. The design lies in the application of that theory to geometry, and then the components determine the soundness of the application.
One concept does not work better than another concept. A design can be better than another design regardless of concept.
You bring up a classic example of the live axle concept's inherent weaknesses. When the chassis of a live axle car does not move parallel to the axle, the contact patch of both tires is lessened.
As such, the most common way to compromise on this is to absolutely minimize the amount of travel allowed by the suspension geometry - thus ensuring that at least one tire always maximizes its contact patch. The team I was on when we designed the 1996 Bodnar supermodified chassis used this to our best advantage, creating a lightweight solid-axle front suspension that offered up uncanny grip and gave us the most nimble supermodified chassis on the ISMA (and later MSA) circuit.
You talk about "leaf springs" being inherently heavy compared to modern suspension. Most "modern" leaf springs are still spring steel because they're used in truck applications. A performance leaf spring (although used in a transverse independent suspension) can be found in the C5 and C6 Corvettes. Their leaves are composite fiberglass resin which makes them incredibly light.
Again, components determine the soundness of the application.
For that matter, the weight of a rear axle. Yes, hoisting around a Ford 9in rearend is a two man job. However, (while unwieldy) I can very easily lift and move the rearend of my MGB. The larger components can be more robustly built for less money. To make smaller components more durable, you must build them with more precision and with higher grade materials, thus costing more money.
A trade-off made when constructing an independent suspension. If you were to construct an independent suspension for the cost of a live axle with the same quality materials as a live axle, it's damn certain that the independent suspension will fail. I've seen too many supermods experiment with independent suspensions and fail because of poor durability for that exact reason.
There is always a compromise in suspension design, and it is made because every concept is flawed. Independent suspension is often the concept that offers the best compromise for some designs. In other designs, it does not. I did not set out to argue that live axle is better than independent, but to prove that neither is an unsound concept. My experience has proved otherwise.
When you take a suspension concept, give it a good design with carefully chosen geometry, and then apply it with good quality components, you will have a good handling (or whatever other goal you're looking for) suspension. So long as one is mindful of this, ANY suspension can offer up truly good handling. This is why Corvette has used transverse leaf springs since 1963, why Lotus stuck with the backbone frame, and why the new Ford Mustang can be a barnstormer on a road course.
Old 02-04-2005, 07:26 AM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Originally Posted by FordJunky
ford already said they have a kikass irs setup which will be an OPTION on the cobra...people didnt want irs for the cobra either, its heritage is straight line, fords gotta respect that. that being said it handles fairly well considering its setup.
Umm ford had a press realse like 2 months back i think stating the only "Cobra" that there is going to be is shelbys no more cobra mustangs. There is going to be a supercharged shelby mustang but it will have a "beefed up live axle" i can scan the article if u like.
Old 02-05-2005, 02:22 AM
yes its theory, but it has been proven that the indep system handles better overall from all tests that has been done. what your showing me in that pic are cars that go in circles on a flat surface, with banks in it. in this case where it goes in one direction on a banked surface, it wont matter as much, whether its indep or not. where it will matter more in is in left to right movements, like the slalom, the s curve, or the lane change, and in rough, or curvy surfaces. indep vs solid with everything else equal, the indep system will more than likely slalom quicker. in this kinda handling movements, the solid axle will react slower because of weight, so it will struggle more in quick changes in direction. about the leaf springs, i said leaf springs used on SOLID AXLES, the ones used in c5 corvettes are different, thats why i said leaf springs on solid axles. i brought up leaf springs, cause you mentioned spreading them further apart. most of those are heavier compared to modern suspension. if you reduce travel, or stroke on a solid axle, you can do the same on an idep suspension, and the indep suspension will again more than likely have better overall handling with everything else equal, not just in one direction, but overall. there would have to be almost no stroke to not matter anymore. but realistically, especially in a road car, theres gonna be some travel, and id much rather have an indep suspension. we re talking about road cars anyway, the new mustang we re talking about is a road car right? also realistically, the road isnt gonna be completely flat, so im sure you know why the indep suspension is better in this area. if you compared the best indep system, to the best solid axle system, im pretty sure that the indep system will handle better overall. again, look at formula 1, if they thought solid axle performed the same as an indep system, im sure they would be using it, because it would be a lot cheaper for the team. im not saying that the indep suspension will perform way better than solid axle, but that the indep suspension will more likely perform better overall, im pretty sure they can be very closely matched.
mr2 club website m3
www.mr2oc.com
Old 02-05-2005, 02:57 AM
Supermodified
Every word out of your mouth is just further proof you know nothing about suspension theory, design, or application.
I like how you're trying to leap on the supermodified as completely irrelevant because it's a circle track car. Nice touch, and predictable for someone who's clearly licking Japanese boots.
What you argue is component. I bring up that most production leaf springs are heavy as they are spring steel but that Chevrolet has proven that leaf springs can be manufactured to be lightweight. That these leaf springs haven't been used in anything except the Corvette/XLR independent suspension is ENTIRELY irrelevant when discussing suspension design. What is relevant is that the technology to make a lightweight solid axle/elliptical leaf spring suspension is readily available and not prohibitively expensive.
You always bring up "all things being equal", unfortunately, this is never the case in design. As I've said all along, different concepts require different compromises in design.
Say you have a specific set of travel parameters to design into a suspension. You need x amount of bound, y amount of droop, n amount of camber gain through the arc of bound travel.
In order to meet your x, y, and n requirements with different suspension concepts, you'll need entirely different suspension designs.
For instance, strut suspension tends to have very little camber gain through the bound travel unless the control arm is very long relative to the height of the strut. However a short strut results in very little natural bound unless the strut connects to the spindle/control arm closer to the chassis pick-up point of the control arm and not the spindle pick-up point. Unfortunately, mounting close to the chassis pick-up point makes droop hard to come by unless you mount the strut low, which compromises the camber gain.
So you continue moving around the components until you determine what geometry meets your parameters.
Then the guy upstairs hands you the dimensions the chassis is going to be and how much of those dimensions is allocated for suspension mounting, and you have to scrap your whole suspension design because the geometry to make the concept work simply won't fit in the dimensions.
This is the key point, and I'm going to put it all in bold so that it'll make it through your thick skull: IT IS NOT THE SUSPENSION CONCEPT THAT DETERMINES THE SUSPENSION'S QUALITY. IT IS THE DESIGN AND THE APPLICATION. You cannot compare suspension concepts because that is all that they are. You insist on bringing up application examples to prove the inferiority of the concept, yet have yet to establish one thing inherently wrong with the concept.
If you want to argue suspension concept with me, start coming up with something a lot better than "Well, if it was better than F1 would use it." Guess what, the concept doesn't fit F1's application, ergo it's not as good for F1 as an unequal length A-arm suspension. In order to set up each corner of the car independent of each other for maximum potential on a specific road course, F1 needs independently adjustable suspension.
If you take a good look at different teams' suspension's, you'll see many different applications of the unequal length a-arm concept, and some work much better than others. But they all use the same basic concept not because it's the best concept, but because it's the concept that fits their compromise.
And, if you really want to get technical, we should mention that F1 "suspensions" no longer include pivot points and instead the damping is done by tuning the rigidity of the carbon fiber of the control arms so that they flex at specific rates. This flex is damped with pushrod enacted torsion bars mounted in the monocoque. F1 suspensions haven't had a droop or bound of more than a few token centimeters since they banned active suspension in the early 90's.
Old 02-05-2005, 05:29 AM
um yea, i made everything up *sarcasm*. licking japanese boots? what the hell lol? it has nothing to do with origin what the hell are you talking about? about the always being equal thing....i know i am, no shit its never the case, im trying to prove my point. wow i didnt know about the overall concept thing, are you serious? woah, that just blew me away. i know about the corvette leaf springs, the ones you mentioned has nothing to do with the c5 leaf springs. i was talking about leaf springs used on SOLID REAR AXLES. more than likely they re gonna weigh more than modern suspensions. we re talking about production cars too, the new mustang we re talking about is a mass produced road car. are we really going to go out and buy a better solid axle system? it would be pretty rare. if i were to change the whole suspension system for better handling, id go with an independent suspension, like a multlink rear, not a better solid rear axle design. the formula 1 cars still use independent suspension, cause its a better design for good overall handling. this can also apply to production cars, not everything being the same of course, but using independent unequal length double a arms/wishbone. they re not only used for good handling/ride compromise, also because it provides better overall handling. if a car hit a bump, or an apex on a turn, the wheels wont be effected as much by each other. the loaded side of the wheel will gain negative chamber on an unequal length a arm, while a solid axle will gain positive chamber on the loaded side of the wheel, which will probably make it lose traction. also, since the suspension components are usually lighter on indep systems, there is less damping needed, so the wheel is able to stay on the road better, it adjusts quicker, which also means the car will be able to change directions quicker. think what you want though, im not trying to do anything, just giving some information.
mr2 club website m3
www.mr2oc.com
Old 02-05-2005, 11:18 AM
kman10587's Avatar
kman10587 kman10587 is offline
Send a message via AIM to kman10587
Sorry if I'm butting in, but maybe a 3rd person perspective will clear this up.
CrzyMR2T, Layla's Keeper is not arguing that a solid axle design is better than an IRS. He's arguing that it is better -in application-. You keep using terms like "most likely", "could be", and "should be". Start putting up some solid proof that IRS is inherently superior to solid axle...but you can't do that, because some of the fastest and cheapest cars you'll find at race day use advanced solid rear axle systems.
Old 02-05-2005, 01:30 PM
Supermodified
Yes kman, finally someone with the mental capacity to understand what I've been saying. What I've been saying is that you cannot discount a solid axle suspension as inherently inferior simply because it is a solid axle suspension.
You can only compare the geometry of the design and the application of the components. Concept = theory, and a theory remains a theory until it's in practice.
And there are too many examples in practice of poor/excellent handling independent suspensions and poor/excellent solid axle suspensions in all forms of motorsport to have a definitive answer.
Should I point out that the GTS class qualifying record at Daytona was broken by Rocketsports Racing's converted Trans Am Jaguar XKR's? A solid axle, four link, carbureted OHV 310ci V8 beast that slaughtered the old 300ZX record.
Old 02-05-2005, 04:03 PM
well my point was in overall handling, like whatever a turn can throw at you, the indep suspensions would be more flexible in that area. another thing is this thread was about how well the mustang handles with its solid rear axle, which is a mass produced road car to be used on real roads, not only on certain race tracks. i understand what your trying to say.
mr2 club website m3
www.mr2oc.com
Old 02-05-2005, 04:13 PM
ec437's Avatar
ec437 ec437 is offline
Originally Posted by ghostx
other sports cars out there under $50,000. I hear about how good it is, but when I play need for speed, (WHICH PROBABLY IS NOT A GOOD EXAMPLE TO USE SINCE IT'S JUST A GAME) the Mustang handles are just about the worst. So what's the verdict on it's new handles?
When I went to the car show I got to play with the handles a little bit. As is typical of american cars, it felt kind of cheap compared to the benzes. But all in all, they are good handles. Nice aesthetic design; although, shaved handles would be best.
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
Old 02-05-2005, 04:48 PM
Re: Re: How's the new Stang's Handling compared to
i know im using terms like, most likely, cause i know that not everything is always gonna be 100%. im sure there are some fast cars with solid axles, im not denying that, some that can even beat some indep systems out there.
mr2 club website m3
www.mr2oc.com
Old 02-06-2005, 02:13 AM
ghostx's Avatar
ghostx ghostx is offline
It makes sense to me that handling setups depend on the application. I will agree with that. So for the SHELBY MUSTANG COBRA, I am eager to see what the beefed up live rear axle can do. I am very excited about this new cobra. The article I read stated that alot of research went into choosing a suspension setup and the best OVERALL (price and handling ability) choice was the live rear axle they engineered. We'll see how it does... anybody else got news or inputs?
