#16
Re: Re: got bar's?
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
#17
Re: got bar's?
I just bought a motorhome with a 71 high compression 350... I'm so tempted to take that motor, and put it in my 85 Blazer
#18
Re: got bar's?
Oh there's only 5000 miles on the re-build
#19
Re: got bar's?
No, it was modified, not really rebuilt. I got it with 40k on it...Did I put 5000 somewhere?
#20
Re: got bar's?
So Rlith; do you know where I can get that stuff in Canada? I've got 3 vehicles that could probably use it.
#21
Re: Re: got bar's?
#22
Re: got bar's?
Oh no, the motor on my motorhome only has 5000 miles... sorry, I paid 2000 cndn for the full motorhome because hey fried the trany
#23
Re: got bar's?
Ahh... Neato...
#24
Re: got bar's?
Thanks Rlith
They should have a chat line in this forum |
#25
Re: Re: got bar's?
This is probably the one thing i agree with rlith on. As an A&P i do not jerry rig shit up on cars or planes that i work on. You have to always be prepaired for worst case senario. especially when your crusing at 32,000 feet. Replace it. it will probably be worth the extra effort. probably wouldnt go to a salvage yard for that part tho. most of them are in pretty bad shape unless its a well maintained car that came in a couple weeks ago w/ low miles. peace
#26
Re: got bar's?
"This frustrates me (only because of how I am) Unless you are stuck out in the middle of nowhere and you took a stome through the core, do it right! Replace the radiator or what ever is leaking instead of trying to bandaid it. Why would you even take the chance of either clogging your system"
again as i stated before.....the problem is not the radiator.....and im thinking of using the bars to stop the small leak at the CORE........ so why would i care if it clogs it..... it would have to be replaced anyway....if the bars didnt work........ so to me i think it worth a shot......... if it works...great...gets me another 40k miles and saves $300...great.... if it clogs......well then i have to replace it anyway. again....what im looking for is someone thats actually used the bars.... not wether you would or wouldnt...use it..or somethin like it. |
#27
Re: Re: Re: got bar's?
I do sometimes buy used engines for just the core if I want to build one up. |
#28
Re: Re: got bar's?
I have used the product as a temp fix, and it does the job with small leaks. If it's a bigger leak you'll have to crimp all the leaking fin's then use the bars. My advice to you is try fixxing the problem properly before the hot weather, then get your coolant system flushed. Otherwise you might have bigger problems with a severly overheated motor. |
#29
Re: Re: Re: Re: got bar's?
Re: got bar's?
It's because they pull the spark plugs... But usually if it's not too bad, simply spray WD-40 in the spark plug holes and use a breaker bar to rotate the engine back and forth a few times. It typically loosens them up without damage to the rest of everything.
