#16
Re: Re: 88-93 chevy truck owners
The ones used back in the late 80's and early 90's, and possibly even now are a "wax pellet" type. No vacuum hoses like the older versions of the eighties. As the wax in the small cylinder heats up, it expands, and moves the lever forward, closing off the heated air from the stovepipe, and allowing the cooler air from the fenderwell. I checked mine out the other day and found that it worked fine, except the valve had jammed so it was stuck on hot air intake. Most of the time, it's the sensor that karks it, and won't move no matter what the temperature.
#18
what would happen if I were to take this stovepipe off? would it hurt my engine or just take longer to warm up?
Remember the old days? You used to have to wait five minutes or more for your truck to warm up? It would run rough if you attempted to just start it up and drive away. The technology then didn't allow for immediate driveability. Sure, they had stovepipes since the sixties, and heat riser valves, but carburetors used anything from manual chokes to crude bimetal springs that slowly moved them off. Modern fuel injection systems are much better at metering fuel, especially when coupled with sensors that give feedback. Defeat any one of those and the others suffer. Think about it, if you take away the warm air during warm up, the fuel takes longer to vaporize, therefore you'll need more fuel to reach the right ratio. This richer mixture may not completely burn, and passes those HC down the line to your oxygen sensor, and your catalytic convertor. Neither one of them are receptive to excess amounts of anything. Since your oxygen sensor doesn't even come into play until around 600 degrees, when it starts to register Oxygen in the exhaust, doesn't it make sense to make the conditions as close to ideal as possible until the system goes into closed loop?
#21
Well Said!!!
#22
The Guys In The Cold Climates Are Right. It Is Best To Fix The Valve Rathar Than To Block It Open. You Might Not Care About The High Emmisions During Warm-up, But On The Other Hand, It Came From The Factory Running Good With That Valve Working. As Vehicles Get Older We Kind Of Expect Them To Not Work As Well As They Did. Keeping All Of The Mechanical Parts Functional Will Help Your Vehicle Running The Best Possible. Sure Advances Have Been Made, After Market Parts Are Available, So Take Advantage Of Any New Info You Can. Just Make Sure If You Up-grade A System, That All Of The Original Functions Are Present In The Upgrade [unless The Original Functions Have Been Prooved To Be Wrong].
#23
Do most aftermarket air systems have a valve for the stovepipe. I was thinking about getting a cold air intake for the summer and was wondering if it would be best to switch back to stock for the winter. I live in the Upper Penninsula of Michigan where it is pretty cold in the winter
