Old 01-20-2005, 05:30 PM
hunter01 hunter01 is offline
Re: Rebuilt motor or replace the rings/pistons
My chilton says for a 91 Z motor the compression ratio is 9.3:1.
It also says " A cylinders compression pressure is usually acceptable if it is not less than 80% of the highest reading. For example, if the highest reading is 150 psi, the lowest should be no lower than 120 psi. No cylinder should be less than 100 psi."
Old 01-21-2005, 07:33 AM
vtmecheng vtmecheng is offline
Make sure you disconnect the ignition coil from the distributor to keep the engine from firing up. It will fire up with one cylinder disconnected so watch out.
Old 01-21-2005, 10:26 AM
Mango™'s Avatar
Mango™ Mango™ is offline
The truck only smokes when I punch the gas or hold it down. Somebody was saying it is the rings, he said if it smokes on start up it is the valve seals, any suggestions? I am thinking of buying an rebuild long block
Old 01-21-2005, 11:22 AM
That is correct, if it is the valve seals you will see a nice blue smoke cloud at start up. If it smokes with the hammer down I would lean toward the rings but a compression test will tell you a lot.
Old 01-21-2005, 06:09 PM
Mikado14 Mikado14 is offline
Compression test, Compression test, Compression test, Compression test, Compression test.
Please do this first. What you have stated about the rings and valve seals is correct generally. There was a recall on 5.3L from '01 that had bad valve seals and it would puff blue smoke when the throttle was tromped. Compression test was good. GM replaced the valve seals under warranty and it is now fine.
Old 02-07-2005, 12:37 PM
Mango™'s Avatar
Well I skipped the test and went on an luck,
I changed the plugs, wires, egr valve, air filter, pvc valve, oil and filter and put in an $10.00 bottle of injector cleaner and IT PASSED, whoo hoo.
Old 02-07-2005, 10:43 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Amazing what maintanence will do eh?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-07-2005, 11:20 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Re: Rebuilt motor or replace the rings/pistons
mango, pvc is that plastic stuff our sewage pipe is made out of, you changed the pcv valve...i hope (sorry grew up with construction work, and i realized you just hit keys backasswords)but on a serious note, next oil change, use high mileage moter oil, synthetic or patrolium its up to you, but remember to totaly drain the moter if your switchen, also the rad cap and fuel filter should prolly get a changen too
Old 02-09-2005, 12:24 PM
Mango™'s Avatar
lol PVC, I will do that on the next oil change.
Thanks all
