| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
#16
Those "heat pipes" are filled with a fluid that boils at low temperatures and those pipe are also under a vacume to increase the heat transfer abilities. Copper is alot heavier than aluminum...but i'm shure you could make it out of aluminum.
I disregard my perceived image in the persuit of knowledge. |
#17
Re: Dual intercooler system
Using the heat of vaporisation and the thermosiphone effect will be a much better way to transfer heat, almost without temperature loss. |
#18
After you do a run and the water is heated up, how is it going to be cooled again? Yep, air. You would basically have to run a small radiator down in front of the car to cool all that water after a run. Plus you need a pump of some sort. I've heard of using engine coolant. Not sure on how well that would work.
Air-to-air are the way to go on the street. Tried and true.
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
#19
For a well engineered air-to-water system, check into the system that Lotus used on the 89+ Esprit. The efficiency claimed is 69%, sustained.
Pre-chargecooled, the car ran a very iffy 10lbs. boost. It now runs a reliable 18 lbs. boost. For some close in pics, see my car in the gallery. |
#20
I have an idea!! Get a bigger air-to-air intercooler and don't worry about the rest of it. I don't think you'll gain anything by running a charge cooler and an air-to-air intercooler, you may actually lose efficiency by doing that.
IMO, bigger air-to-air intercooler and forget the charge cooler.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
