Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-18-2005, 06:43 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: CV Joints "How Long Does Yours Last"
Not sure, but they are similar in properties. Considering the difference in cost and the lack of need for heat resistance, I would bet it's a standard petroleum grease-based formulation.
In any event, they would both rot rubber. Just like both dino oil and synthetic oil have the same seal compatibilities. I don't think there is anything special about CV joint grease.
Nitrile rubber is another very high-quality rubber material. That is another possibility for the CV boots.
Old 01-19-2005, 01:50 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
Brian and ice745,
I did some research. From the WD-40 web site FAQ's;
What surfaces or materials are ok to use WD-40 on?
"WD-40 can be used on just about everything. It is safe for metal, rubber, wood and plastic." ...
It does say in the same paragraph that it is a petroleum based product.
www.wd40.com/Brands/wd40_faqs.html
Mike
Old 01-19-2005, 07:37 AM
Brian R.'s Avatar
Resident Chemist
"Rubber" is a pretty generic term. I would not use it on standard natural rubber. Others are ok, I guess. Your CV boots are not natural rubber.
WD40 is simply very thin lubricating oil in a carrier. Use it where you would safely use lubricating oil and nowhere else. If it works for your CV boots, then it works...
Old 01-19-2005, 02:23 PM
AF -Advisor
Brian,
Thanks for your input. I will continue to use it on my cv joint boots.
Mike
Old 01-19-2005, 10:06 PM
Brian R.'s Avatar
Resident Chemist
Here's another use for WD40:
http://today.reuters.com/news/newsAr...BRICANT-DC.XML
Old 01-20-2005, 08:32 AM
AF -Advisor
Brian,
Thanks, that made my day, LOL.
Mike
Old 01-20-2005, 02:33 PM
typesix typesix is offline
WD-40 is good bug killer, even works on roaches.
Old 01-20-2005, 08:46 PM
steve9899 steve9899 is offline
Re: Re: CV Joints
"What surfaces or materials are OK to use WD-40 on?
http://www.wd40.com/Brands/wd40_faqs.html
Old 01-20-2005, 10:35 PM
Brian R.'s Avatar
Resident Chemist
It is suggested that you read prior posts before responding to a thread.
Old 03-31-2005, 06:25 PM
sbretana sbretana is offline
Re: Re: CV Joints
I have a question...
I just got a 92 Camry XLE as a hand me down.
It is in good shape except for that I took it in to get looked at, and they sais that CV boots are torn and need to be replaced. The dealer quoted me $250 each used (and I need both) or $400 new plus labor! This just seems extremely high to me, I looked on the internet and I am not sure exactly what part could be costing so much...
He also referred to them as "CV Axles" he said that the joints will become dry becuase the boots are torn?
Any advice? = )
Re: Re: CV Joints
Sorry this is all new to me...
Old 03-31-2005, 09:18 PM
Brian R.'s Avatar
Resident Chemist
I was talking to Steve9899
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-31-2005, 09:23 PM
Brian R.'s Avatar
Resident Chemist
Re: Re: Re: CV Joints
Any advice? = )
Normally the axles are replaced with remanufactured axles, not used. Maybe that is what he meant. He is most likely referring to replacing the entire half-shaft on both sides. Once the boots crack open and let dirt and other gunk into the CV joint, it is more trouble and similar cost to remove and dissassemble the half-shafts, clean the CV joints, and reassemble and replace the half-shafts, as it is to simply replace the entire assembly with remanufactured ones. New ones have little or no advantage over remanufactured ones as long as the source of the remanufactured half-shafts is reliable.
Old 04-06-2005, 04:10 PM
Po Pilot Po Pilot is offline
Send a message via ICQ to Po Pilot Send a message via AIM to Po Pilot
How easy is it to change the half shafts? I have a friend with a 96 that needs hers changed badly - both sides.
Old 08-30-2005, 11:29 AM
mrtwo mrtwo is offline
Since I first found the boot split, it has been more than 10k miles now. And the Joint is not making any noise. I am wondering how long can it last?
