Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 08-28-2020, 07:34 PM
maxwedge maxwedge is offline
A990 racer
Re: Wheel Weights
If they are the same size how would that happen?
Old 08-28-2020, 07:51 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Re: Wheel Weights
Simple: Lighter wheels shift more weight above the vehicle's metacenter!
Old 08-28-2020, 08:39 PM
A990 racer
Re: Wheel Weights
Explain that theory, see my race car, that had lite weight Centerline wheels, of course for a split second during launch that could occur, normal street driving the unsprung weight of the wheels will not change static or dynamic center of gravity. Of course you know that metacenter calculations apply to floating structures suspended in water.
Old 08-29-2020, 06:32 AM
Cool Re: Wheel Weights
It's really quite simple: Let's take a more extreme example:
Replace the 22lbs(US) OEM rims with 12lb alloys at each corner. That right there is a 48lb weight reduction right there, assuming same size and aspect ratio are preserved.
Then, install an aftermarket moonroof, about 40-50lbs.
You've just shifted about 50LBS of weight from close to the ground to approximately 4 1/2 to 5ft above! Even my cats can figger that out.
Add 10-15lbs of roof clips for skis, and, you see where this is going.
Old 08-29-2020, 06:58 AM
A990 racer
Re: Wheel Weights
Correct, the moon roof would certainly change the center of gravity, not so the wheels. So here we are at an impasse , fun though.
Old 08-29-2020, 07:27 AM
CapriRacer CapriRacer is offline
Re: Wheel Weights
But the benefits outweigh the disadvantages. The CG would only move a tiny bit, but the unsprung weight is reduced a lot.
