Old 01-03-2005, 03:22 PM
soccerplaya soccerplaya is offline
Send a message via AIM to soccerplaya
Re: No Spark (HELP ME)!!!!!!!!!!!!!
I tryed replacing that to. Still nothing
Old 01-03-2005, 11:34 PM
i have tryed the main relay and that didnt work. I called the honda dealer and asked them. They said that i have tried everything that they would have. The guy said that the next step is to in depth diagnostic. How would you do that
Old 01-04-2005, 08:03 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
get yourself a helms manual and a multimeter.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-04-2005, 01:09 PM
All the wires work to the distrubuter they all have resistance. I used a multimeter. What else could i check with the multimeter? I have the chilton manual for it.
Old 01-04-2005, 03:28 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Re: No Spark (HELP ME)!!!!!!!!!!!!!
you may have got some bad wires/plugs/module/coil,
when you bought them brand new,
its happened before & it could probably happen again,
my mechanic said he would be over here at 5:30,
he should know some symptoms for this problem,
I'll write back.
In the process of B00stin my D
Old 01-04-2005, 04:20 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
has the car been running before? do u have the right dizzy? is it wired correctly? no wires cut anywhere? firing orders correct? timing belt is right? coil is hooked up right? put the cap on right? put the screw in the rotor to hold it?
Old 01-04-2005, 07:16 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
no codes? there's gotta be codes...even if the check engine light isn't on, check for codes. Ur sure you here the fuel pump "hum" when you turn the key to on?
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 01-07-2005, 12:48 AM
Yes the cars has been running before. Iwas driving it down the road and then it just died. My tach. peaked right before it died. Yes i have the right dizzy. Yes the coil is hooked up. its a new dizzy. new coil,New ICM, new wires, new plugs, new main relay. I did the timing. The timing belt is fine.
Old 01-07-2005, 12:49 AM
oh ya and there isno codes. i have put two diffrent computers in it to.
Old 01-07-2005, 12:54 AM
arodg25's Avatar
arodg25 arodg25 is offline
is it mabey posible that he could have installed the new dizzy 180 degrees off?
Old 01-07-2005, 01:13 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Usually if the dizy if off 180 degrees you'll get back fire. One thing for you to double check - from the coil to the cap there is a long pin backed with a spring. It's possible that you broke that pin while putting on or off and now it's not connecting. I've done it myself. Double check that - it's easily over looked. Also, make sure all your wires inside the dizy are tightly screwed down. I had my tach wire come loose once, so it does happen. Other than that I'd say try another dizzy. I've gotten a bad one before myself. Hope this helps.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 01-07-2005, 01:31 AM
The pin is not broken. i have checked that to. i am thinking that i mit have gotten a bad dizzy. I well try and get a new one agian.
Old 01-07-2005, 04:15 PM
bambam89lx's Avatar
AF - Advisor
I think i have the solution.....sounds like this is the problem....
check the ground on your thermostat. I have a REALLY good feeling it's either not tight or it's not connected. If it isn't that, make sure all the other grounds are connected too...valve cover and the tranny to chassis then chassis to negative terminal on the battery....
I don't think I'm wrong on this one tho...because the RPM spike sounds %100 like a bad or broken ground at the thermostat. That is the ground for your engine wiring harness...
Old 01-07-2005, 05:52 PM
take you tach wire off,from the distributor 1st,
& see if it will start.
Old 01-07-2005, 09:38 PM
2CrX's Avatar
2CrX 2CrX is offline
Is it getting 12v at the coil?
