Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 10-03-2005, 09:27 PM
Jon51 Jon51 is offline
Re: Re: 1993 Dodge Dakota Problems
Originally Posted by bmayer13
Does anyone have any suggestions as to why our 93 Dodge Dakota pickup has lost interior lights, dash lights, backup lights, A/C all of a sudden and all at the same time. Book says it could be #2 fuse but in checking the fuses it's a dummy - no power there. Could it be entire fuse block needs to be replaced or could it be something else causing this? Any suggestions are welcome and appreciated. [email protected]
I've had 2 1993 Dakotas with this problem. Bad ground in the interior wiring harness. If driving, I usually just beat on the dash until the lights come back on. (HINT: check this connection)
It could be the ground connection from the harness to the dash OR the dash to the body.
Old 07-17-2007, 04:51 PM
david_beggs2001 david_beggs2001 is offline
Red face Re: 1993 Dodge Dakota Problems
Since I cant seem to find where to start a new thread! I have to turn my key off and on a few times every time to build up fuel pressure. this started after i replaced the fuel pump. its driving me nuts. is their some kind of valve or something that holds fuel pressure?
Old 07-21-2007, 08:10 AM
93 dodge need help 93 dodge need help is offline
I have a 93 Dakota 3.9 was driving down the road truck just quit running. I went with what was logical in changing and that was the Fuel Pump. I did this because there was no sound coming from the pump when I turned it on. New Pump still nothing. It will crank (rrrrrr,rrrrr ) but will not continue and start. Any ideas. I am not big on fixing truck and hate to have to take it to a service center if I can fix it myself.
Old 08-23-2007, 06:52 PM
rhandwor rhandwor is offline
I would check for corrision around the ground terminals. This will cause you to loose dash lights.
1993 Dodge Dakota extended cab Jayr37A Dakota 1 04-22-2010 06:04 PM
1993 dodge dakota 318 hesitation probms 95cavspeed Dakota 0 05-15-2007 08:21 PM
1993 Dodge Dakota Gas Mileage 93gdodgedakota Dakota 4 04-09-2007 07:47 PM
1993 Dodge Dakota Trouble Arthur Trueblood Dakota 2 10-23-2003 08:50 PM
