Old 03-08-2002, 10:30 PM
super 96 accord's Avatar
super 96 accord super 96 accord is offline
Not sure what is interchangeable between N/A and turbo, but two things that are NOT are headers and a CAI.
Old 03-09-2002, 08:45 AM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
yeah..i know parts interchangability between N/A and Turbo. its kind of common sense. I was asking about interchangability of exhaust between a 97 and 2000 civic. also what would add performance to a turbo and N/A car and not have to be thrown out when i go turbo
Old 03-11-2002, 05:35 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
Nitrous!
Mild cams. Cam gears. Throttle Body. Air/ fuel computer (piggyback or full aftermarket ECU). Brakes. Tires. Suspension.
Old 03-11-2002, 09:09 PM
white97ex's Avatar
what i will probably end up doing, is doing all the necessary upgrades..then go turbo. i know brakes are a must..as well as suspension. can you get big brake kits with out going to a larger wheel or is going to a larger wheel to my benefit..i want it to look as stock as possible. the only body work i'm doing will be to paint my bullet molding, and color match the side skirts...again...i dont know what we would do around here without the likes of fritz
Old 03-11-2002, 11:26 PM
Most big brake conversion kits I know of require the use of larger rims. Usually about 17's. You can't exactly fit some 14 inch rotors on 14/15 inch tires.
Old 03-12-2002, 09:18 AM
white97ex's Avatar
14 inch rotors are some awefully big rotors for an import.....of course i havn't looked into big brake kits yet. i dont want to go much bigger than a 16 inch wheel. I dont want a huge increase in rotating mass. I can get 16's that are lighter than or weigh the same as stock wheels
Ultimate Exhaust System !!! erwin turb00 Car Videos 6 09-07-2009 07:09 PM
Turbo Exhaust on a Non-Turbo JoeShmoe Engine, Transmission and Drivetrain 10 08-15-2007 09:41 PM
'95 Civic info, turbo, exhaust, intake, etc... 95CIVIC95 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 02-03-2002 01:17 PM
92 turbo exhaust 92TSupra General 0 01-23-2002 09:59 PM
