#16
Re: 1998 Tahoe 5.7 Usually wont start, but sometimes does
Guide lines for hard to start.
First check for spark to spark plugs at 2 or more plugs. Then check for proper fuel pressure. If spark and good fuel pressure then move on to injector pulse check. Also if you have spark feed it a little carb cleaner not starting fluid and see if it will run. On the fuel pressure check. Hard to start cold. Check cold start fuel pressure. Check engine running fuel pressure. Check engine running on the road fuel pressure. Then shut it off and watch for fast leak down. Pinch off at rubber part or block off return line and check full pressure. Most Later V6 and V8 gm engines should have 60-66 fuel pressure. Cold start should be 64-65 lbs of pressure. If you do not have full fuel pressure on a cold start the injectors will not squirt fuel. Even 1 or 2 lbs low will give a no start. Do not leave home without it. Engine running should be 60-66 lbs pressure depending on engine load. Full pressure with return pinched off should be 75-85 or more. And if it has a fast leak down after shut off you have a leak. Post back fuel pressure readings. MT
#17
If you have spark to plugs then jumper the fuel pump prime conection or see if it has 12 volts on it when no start. If jumpered or it has 12 volts on it the fuel pump should run. Mt
#18
where's the fuel pump prime connection?
#19
just saw this old post. i'll try to find the fuel prime connection and try jumping it and check voltage.
thanks MT-2500 |
#20
well i was gonna check the voltage, but when i went to start my tahoe, it started, so i turned it off, unplugged what i thought was the prime connector, to make sure that was it, i checked if it would start (which it shouldnt), but it did. so i guess i dont know where the prime connector is. but my tahoe started over and over again with no problems. fuel pump kicked on everytime. i dont wanna drive it, till i find out whats going on.
#21
mine was doing something similar. i found out it was the battery connection. gm used 2 connectors on the battery terminal. the conct area between the 2 becomes corroded. i cleaned mine, put on some anti-corrosion gel, and put it back together. have not had a problem since. when i was reseaching for mine i found that it could also be the anti-theft device. if you need to bypass it, you can find out how on this site. do a search for "passlock bypass". good luck.
#22
Check the fuel pressure and it might be a fuel pump agian and did you replace the fuel filter when you replaced the fuel pump?That is part of the warrenty of a fuel pump,replacing the fuel filter.The old fuel filter is full of dirt and trash that will ruin the fuel pump right awayThe fuel pressure specs are 60-66 psi and will not run under those specs.
