#16
Re: Cd player code
I work for acura and you have two options to get the code. You can either go to the fealer where the car was sold, and they can look it up on file for free, or you can take it to any acura dealership and they have to get the serial number off the radio and look up the code. Thats why they charge you money, we actually have to take the radio out sometimes to get the serial number to then get the code. If you can get me the serial number, i can get you the code....i,m not supoesed to, but i'll hook you up since your in a fix.
94' Del Sol VTEC (B16A3) SOLD. Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles. |
#17
Re: Cd player code
^Here's one Acura tech who just made my A list.
![]() I've got a fever. And the only prescription is more cowbell... |
#18
Re: Cd player code
Privatebigandrew
Will my VIN work? Because I tried to take the cd player out and just scratched up all of my dashboard around it. Thanx for your help. |
#19
Sorry, but the only way to retrieve it is by the serial number on the actual radio. As i remember correctly, the Radio in the RSX "is" a real pain to get out....the easiest way once you get all the screws out is to pry it from behind through a slot at the left side of the glove box. (you have to drop the box)
#20
Re: Cd player code
Thank You for your help but I got the code from a dealer for $25. Yeah they did have to take the cd player out but they did a much better job than me. Now I have music to drive to.
#21
for all you ppl that need the code as bad as i did and dont want to drive another day without the radio hit me up for $20 ill do it without scratching up your radio or even taking it out. i paid $53 for my code and when the guy went to give me my code he left and i wrote all of them down. If i cant help you i wont charge you hit me up (714)598-5056
#22
Re: Cd player code
I'll sleep with your girlfriend for 50. If she doesn't get off, you don't pay...
#23
Re: Cd player code
so I had the same problem with my battery dying...leaving your lights on overnight is never a good idea...and was dreading paying the 50 something dollars needed to get the VIN off the back of my cd player. Went to the dealership, told them my problem, and had it fixed in about 3 seconds. The code for my cd player was located on the outside of the glove compartment when you open it up. That easy...
