Old 12-28-2004, 11:17 PM
derblazer derblazer is offline
Noisy Engine
So why does everyone dis BlazerLT? He has given me very sound advice in the past. I think you are right about the fuel filter; at least that's a good and inexpensive place to start.
I have used a higher grade of fuel 91 or 93, who can really say what is is for sure. I used to hall fuel for a living and believe me when I say this, "You put the gas in the hole they tell you to put it." Nugh said. By the way BlazerLT I haven't replaced the fuel filter yet and it is still pining away. SO the upgrade on gas octane didn't do a thing. The oil pressure is around <50 when cold and around 40> when warm. Goes up and down on acceleration & deceleration.
Old 12-29-2004, 01:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Noisy Engine
I would change the fuel filter soon, a lean mixture will cause detonation and higher combustion temperatures. This could lead to damage over time.
The filter change is a bitch, but it is worth it.
Also, your oil pressure is perfectly normal and is nothing to worry about.
BTW, just to recap, do you have any check engine lights?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-29-2004, 05:11 PM
Fireplug Fireplug is offline
Re: Noisy engine
BlazerLt
I have seen a lot on s-10 Blazers with the ping he is talking about and most times it was do to carbon build up on the pistons causing a hot spot.
We used GM Top Engine Cleaner to help clean off the pistons and boy did it work. You guys talk about seafoam doing the samething so That is waht I would do right after the fuel filter change
Old 12-30-2004, 06:27 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Noisy engine
Change your oil soon after the treatment with Seafoam. I use a 3 foot length of aquarium tubing to extend the PVC line going to the intake manifold over the front of the engine, or off to the side of the fender.
After the truck is warm and up at operating temperature, (Take it for a 10-15 minute ride down the highway) pop the PVC boot off the valve itself and stick the hose into the boot and then let the truck suck up the Seafoam from the bottle *slowly*. Too much and it will hydrolock your engine and make it stall....permanently. Allow only a fine, trickling mist be drawn up through the aquarium tubing. When half of the bottle is gone, you should see a cloud of white smoke that smells *awful* coming out of your exhaust. If you are doing this correctly, there will be no reason for you to advance the idle of the engine manually. If you are drawing up too much, you will hear the engine start to stumble and missfire. Reattach your PVC and shut the engine off for 5 minutes.
Restart it and be on your way..... to the automotive supply store. Pick up what you need to do a complete oil change. (Oil, filter, etc.) Once you get it home, it should have quit smoking, and blown all of the crud and seafoam out of your exhaust. Once home, dump the other half of the bottle of Seafoam into your engine oil after removing and draining your old filter for a few minutes. Re-attach the old filter and start the engine. Let it *IDLE* in the driveway for 20~30 minutes. Perform your oil change. Sit back and relax now, enjoying that purring motor - you're done.
Old 12-30-2004, 08:30 PM
blazee's Avatar
blazee blazee is offline
Problem?
If you are as sensitive to vibrations and any engine noise as I am, it could just be a faint pinging caused by an inferior oil filter. Do you use Fram? If so that is your problem try NAPA Gold. Fram filters are junk. From personal experience NAPA gold is the best...even better than AC Delco.
Old 12-31-2004, 01:02 AM
wolfox's Avatar
Re: Noisy engine
Excellent point! It may take some time for a lifter that got a bit of air into it to work properly again. A filter with a bad/faulty anti-drainback could allow air up into the system at start up and make one heck of a racket. Changing the Penzoil filter for a regular AC Delco when I first bought my truck used cleared up a "sticky lifter" noise I was getting at startup. It would grow faint over half an hour of driving, but would not go away completely. A day after I swapped the filter, it silenced right up.
Old 12-31-2004, 05:39 AM
ricksza's Avatar
ricksza ricksza is offline
Re: Noisy engine
Detonation can also be caused by a lean condition, like a vacuum leak. The engine doesn't have to be hot, just the combustion chamber. Put a scanner on it and stop guessing. Too much detonation can cause internal engine damage like broken pistons and rings.
Old 01-01-2005, 09:13 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Noisy engine
Originally Posted by Fireplug
BlazerLt
I too used the top end cleaner and will NEVER do it again.
hat I was left with was a completely fouled engine with all sparkplugs fouled SO bad the engine ran worse after the cleaning.
I will stick to my Water Decarbonization which does the same job without the oily residue ruining my ignition system.
Old 01-01-2005, 11:37 AM
ricksza's Avatar
Re: Noisy engine
If you use GM's Top Engine Cleaner, you won't have any problem if you follow these directions exactly.
With the engine running at a higher idle slowly pour about half of the can through the Carb or throttle body. When half the can is done, quickly pour the rest. The engine will stall. Turn the key off and let it sit overnight. The next day when you start it up, it will pour out lots of black smoke for a few minutes, but the carbon in the engine will be gone.
With the 4.3L "W" engine it's a lot tougher because of the way the intake is designed. I have an adaptor that plugs into the PCV valve which will basiclly do the same thing just slower and unfortunately not as well.
Old 01-01-2005, 01:24 PM
Re: Noisy engine
I have used GM Top Engine cleaner on hundreds on cars and trucks and NEVER had a problem with any of them. If done correctly it cleans the heads and pistons real good. BY-BY Ping
Old 01-01-2005, 06:30 PM
BlazerLT's Avatar
AF -Advisor
Re: Noisy engine
I did use it correctly and right to the letter.
After I pulled the plugs and they were all badly fouled.
Just stating my experience.
Old 01-01-2005, 06:35 PM
Re: Noisy engine
OOOPs did not mean to imply you did anything wrong. It sounds like the cleaner did its job.
Old 01-01-2005, 06:39 PM
BlazerLT's Avatar
AF -Advisor
Re: Noisy engine
Hehe, maybe the carbon fouled my plugs.
Would make sense.
