Old 12-29-2004, 07:49 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: muffler question
True (exept the oil pressure maybe), I am doing some extensive work on the car that is why the rest of the exhaust is not on
Old 12-30-2004, 12:24 AM
CORE402's Avatar
CORE402 CORE402 is offline
Re: Re: muffler question
Originally Posted by 92rs25th
You'll lose oil pressure , ruin your valve and kill you mpg with only headers. Running only headers is for car shows and engine tests , Not permanent. It's extremely bad for your car.
Where did you hear that? I know running with just open ports is bad but since when was it bad to run with just headers? Perhaps doing such on a new car would twak out that comp a bit but I dont know about oil pressure and hurting valves!!! If you want to go fast just put a foot of pipe after the collector (long tubes) then you will get maximum power out of the ride. Just prepare for ringing ears and many headaches.
1973 Camaro
AFR 195cc heads
CNC Motorsports 383 short block
Comp Cams hyd flat tappet
TH350
Dual 3" exhaust (LOUD)
Corporate 10 bolt w/ all new internals and axles
Old 12-30-2004, 12:44 AM
sivic02's Avatar
sivic02 sivic02 is offline
if your worried about the muffler getting stopped up over time then yes it will, a little bit. I bought a used exhaust from someone and I just made a makeshift cap out of rubber and put it on one end of the exhaust and turned it on and got quite a little bit of crud out of it, so if your worried about it then why not give that a shot
Here's to being single, seeing double, and sleeping triple
Old 12-30-2004, 01:10 AM
chevy_chic20041 chevy_chic20041 is offline
Send a message via Yahoo to chevy_chic20041
Originally Posted by LT1MAN
ive had the same flowmaster for a while now on my 94 and it was also on my last 94, there is a total of about 105K on the muffler. do they lose any flow after a long ass time or anything or am i straight until it rusts through or something, it still looks to be in good shape from the outside and it sounds great still. just curious if i should get a new one.
your car looks really good
Old 01-04-2005, 11:05 AM
LT1MAN LT1MAN is offline
Banned
why thank you
