#16
Re: 92 Accord idle problem!!!
You're right - we have two of you with two different problems in one thread. Confusing.
#17
DamienWC: Its probably the break pump thats putting a load on the engine and shifting it to the erratic idle. today it was so freakin cold outside, it took 30 min for my car to warm up, and it was going u and down the whole time... I was told its my thermostat that is stuck open, so the coolant circulates (when it shouldnt), causing a sensor to show a cold temperature, an other (for the engine) to show warm. so the ECU is constantly trying to adjust itself with the conflicting messages, thus resulting in an up and down. I bought a new thermostat today, gona change it when its a bit warmer, ill let you know what happened!
#18
I Damien, i think that you may be right ,to me it make sense, i will make some check on that side. thank's Marc |
#20
Re: Re: 92 Accord idle problem!!!
New to the Forum, but I have the same problem but the idle doent resume its normal idle at all. On start up it revs up and down but also at stoplights, stop signs, and basic idleing. In normal tempature to me is 80 to 100 degrees, I live in Texas, its not due to the weather. Cold or hot it has the same peoblem. I havent yet cleaned the sensors but when I do Ill be sure to post my findings.
#21
Could someone give me some info as to where these sensors are at?
#22
ill try to post some pics tomorrow, of exactly where the sesors arte located.
#24
Hey yo Nick........... can you post them pics for me? I've been trying to find them without any visual help but to no luck.
#25
OK guys, has ANYBODY fixed their problems yet? Somebody PLEASE post something that will help me out. This problem is getting VERY annoying and I want to get it fixed ASAP.
#26
I'd check those first, it's easiest to do -- i had similar problems with my 93 and living in SoCali new that temperature wasn't an issue -- all i ended up doing was cleaning the IAC and adjusting the idle screw This illustration from the 1900-93 honda accord service manual published by haynes... hope it what you need:
#27
NotYourAverageGIrl........... thanks for the pic, much appreciated. Although I did clean all 3 of the areas in the pic and still no luck.
I think im just gonna take the damn thing to a mechanic and get them to look at it.
#28
OK......... I know its been a while since anyone posted on this topic, but i've got another question relating to this issue. Yesterday I had to replace my starter ($180 f'n dollars by the way) and when I got the new one put on the idle problem was fixed. I turned the car off, turned it back on, and the idle problem is there again. My question is, why would the problem be fixed (even for a very short time) after I replaced my starter?
#29
Coincidence (or something got disturbed when the starter was installed.)
