Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-25-2005, 08:23 AM
lukecarr lukecarr is offline
I do not know how to tell if the fuel pump is running except for the wining sound before the engine starts. I do have the jeep running rouger in the cold. I also have a rougher idle in geer with not rpm change, just like you had. I do have a problem when it is cold outside sometimes I have give gas to get the engine to start. When it starts is sounds like it could stop, for a for seconds, then just rough idle. Most of the time when it is cold outside it does sound rougher. How would I go by to check the fuel pump out? Thank you for your time. Sorry it took me so long to reply.
Old 03-25-2005, 08:25 AM
Re: rough idle only when in gear
Originally Posted by collinb
Check your motor mounts, putting it in gear will normally put more stress on the mounts. If one is snapped it will not be able to fully absorb the vibrations.
How do I check my motor mounts? I am trying to learn.
Old 03-25-2005, 09:19 PM
gunjes gunjes is offline
let me check to make absolutely sure of the voltage that is supposed to run to the fuel pump. I'll write as soon as I know. I never tried giving it gas ,as it is fuel injected and should run at 40 psi continiously (if you have a gauge you can check this at the fuel rail port). Anyway let me check and I'll write.
Old 03-26-2005, 03:25 AM
Bernando1 Bernando1 is offline
I don't think it is the fuel pump. I just replaced it, it is running at 40 psi. Any other ideas for the rough idle?
Old 03-26-2005, 06:46 AM
Could it be the pcv valve being cloged, or the ccv valve being cloged? I do get oil in my air filter.
Old 03-26-2005, 09:16 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Yes deffinately
The PCV valve cause many slight rough idle problem. and it's only a few dollars. you could check it by pulling it out and shaking it if you can hear it rattling then it's good. You should be able to blow through one end but not the other.
If you gonna remove it, make sure to warm the engine first, this will loosen the rubber grommet to make it easier to pull out. I did this with the engine cold and end up breaking the PCV valve off.
