#16
What if when I bleed the system fluid does squirt out the bleeder valve?I guess that would mean the master cylinder is good?
What could the problem be then? |
#17
Re: 3rd gen brake problem.
that doesnt mean its good.if your not losing fluid and the pedal goes to the floor,you have either a bleeding problem,or a bad master cylinder
#18
So that means if I have a bleeding problem I should see fresh fluid leaking somewhere right now.
Im pretty confident I dont have a leak anywhere so I think it might be the master cylinder.What do you think? |
#19
How many miles can a master cylinder under normal driving conditions before they go bad?
#20
if you have a leak you will see fluid on the ground or on parts .If you have a bleeding problem,that means that air in the brake system exists due to it not being evacuated properly.
#21
mayhaps rebleed the system,and get better results.
#22
I see,but the braking system has worked fine for 15000 miles since I last worked on them until now.Will air that was left in there then be a problem now or do you think my master cylinder simply went out?I checked the car again and dont see any leaking brake fluid any where.
#23
yeah its probably wasted. if expence isnt a big deal go ahead and replace the booster too.
#24
I know for a fact that the master cylinder is original,How many miles can a master cylinder take before it goes bad?
#25
Also,i forgot to mention that when I drive I have to pump the brakes in order to stop.It stops if I push it down to the floor once but stops better when I pump it 2 or 3 times.What does that mean.
#26
same thing
#27
same thing,meaning a bad master cylinder?
#28
yes sir
#29
thanx,I gotta go,the LAKERS are going to kick the Suns arrsss!
#30
Is it me or does Kobe Bryant always throw up a brick when the games on the line.
NE wayz,I installed the new master cylinder today and now I dont have to let ricers pass me by.Thanks everybody,my brakes r all good in da hood now.
