Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-09-2004, 04:13 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: engine gives out when floored
and if that doesn't solve the problem, maybe go over everything installed and see if everything is properly connected,
was this a sudden thing or did it happen after an upgrade?
Old 12-09-2004, 07:39 PM
redtegb18b1 redtegb18b1 is offline
Send a message via AIM to redtegb18b1
alright i'll try that(wires) and the guy i bought it from said he got the ecu worked on or smt??? and it redlines at like 7600 now when it stock redlined at like 67 or 6800 but he has had some work on the ecu if that helps but i'll try the wires and check the fuel filter and pump thanks alot guys and when i do change the wires what do u suggest i get.....
Old 12-09-2004, 07:42 PM
this happened about a week or 2 after i bought the car when my friend was driving and he floored it and it started doing it
Old 12-12-2004, 08:22 PM
Rating's Avatar
Rating Rating is offline
Send a message via AIM to Rating
One of my friends had the same problem about a week ago with his civic. about 6k the motor would just shut down basically. I told him it was a fuel problem and he should check to see the fuel filter was clogged up. And sure enough it was, we ended up putting a new fuel filter in and the problem went away. However after it was fixed, when idling his car would idle up and down sounded like he was pumping the gas a tad, but actually wasnt. Donno what thats about, but im sure well figure it out. but anyways try changing the fuel filter might be clogged.
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
Old 12-12-2004, 10:18 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: engine gives out when floored
Excellent advise
Your friends idle issue is more than likely the IACV you can do a search here in the Integra forum and you will find lots of information on it.
Old 12-15-2004, 12:26 PM
Rating's Avatar
Haha yea ive seen about 20 idle threads
thanks bro
Old 12-17-2004, 09:43 PM
ok so i changed my fuel filter and it didnt do ne thing and my plug wires should be coming in within a couple days so i'll keep you guys posted on what happens
Old 12-28-2004, 10:16 PM
so we figured out what it was.......it was a bad throttle position sensor but its all good now thanks for al your help
