Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 12-27-2004, 09:01 PM
jettaboy jettaboy is offline
If your Check engine light is on, it probablly wont hurt the car too drive, but I would first have it scanned at autozone, The first thing I would check is the Mass air flow sensor, if it has not ever had a new one it should be due. also gas cap 3 clicks! bottom line is there are around 200 diffrent things that can set that light off. So you need to get it scanned to find the real problem.
Old 12-29-2004, 03:49 AM
Aerowitz's Avatar
Aerowitz Aerowitz is offline
Send a message via AIM to Aerowitz Send a message via Skype™ to Aerowitz
Aha, the notorious MK4 Jetta Engine Light problem...
It's your O2 sensor. Get it replaced and the light should go away. As for the transmission, if it's automatic you should get the CPU reworked since it's usually dumber than a rock. Automatic transmissions in MK4 Jettas like to slip and shift violently at times because they're so dumb.
I had the same problem in my Jetta and the light went off once I started it after the sensor was replaced.
Heh heh. Don't you hate those cupholders? Worst design ever.
12/9/05 - 8/26/07 Disappearance. But I'm BACK!
Old 12-29-2004, 04:02 AM
Aerowitz's Avatar
Arrgh. My bad.
It's actually the Mass Airflow Sensor. This is the price I pay for a crapload of caffeine combined with fast fingers on the keyboard... God I need to sleep...
I also failed to notice that someone already told you that before I did. Don't blame me! It was on the second page already, but my computer kept freezing halfway down that guy's list of problem codes...dunno why. I should have just hit page 2 and not talked at all. Whatever. I'm going to bed.
Old 01-02-2005, 06:23 PM
82KnightRider's Avatar
82KnightRider 82KnightRider is offline
My sister says her check light just went out about 2 weeks ago and hasnt come on since.Now her tranny is giving her problems,it has a major problem shifting from 1st to 2nd.When I accelerate from a stop the revs go all the way up to just before redlining and then it switches to 2nd.Its an auto ,shes scared,and we appreciate all the advice we can get.
Old 02-16-2005, 11:11 PM
VWAudi VWAudi is offline
Re: check engine lihgt problem
My 96 Jetta GLS has an engine light on. All it needed was ne spark plugs. Also, the elec. code insert is at the ashtray (is on the 96) anyway. Just remove the astray and pull back the little black plastic piece to the side. Take it into a shop, and they plug it in and tell you which out of the above 1000 problems it is. I'll bet spark plugs!
Old 02-20-2005, 11:23 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
A check engine light can come on if there is a fault stored in the transmission control module.
Old 03-04-2005, 07:07 AM
15thurman 15thurman is offline
when did she last put gas in the tank.
the tranny will feel like it is slipping when it is running out of gas.
Originally Posted by 82KnightRider
fuggin a man,you didnt have to get crazy like that!lol.thanks, but my last question was if a slippery tranny will make the check light come on?
Old 08-15-2005, 09:02 PM
SSZero's Avatar
SSZero SSZero is offline
Would anyone by any chance know what to do to actually fix a P0170 and P1104 check engine code? I'm not sure, but my friend and I were thinking the P1104 code means I need to replace my MAF sensor... Any ideas?
'96 Green Eclipse GS-T
Stock for now...
Old 11-17-2005, 03:23 PM
greeffs greeffs is offline
Re: Re: check engine lihgt problem
My 96 Jetta auto failed the emmision test because the code P1582.....
idle adaption at limit
what does this mean and what is the suggested fix. car runs great but the code keeps on coming on even after i clear it.
thanks for the help.
Old 01-24-2007, 11:28 PM
pablocruz69 pablocruz69 is offline
Question Re: check engine lihgt problem
I have a P0441 Evap emission control system purge flow fault, I am not sure what this is but I cannot figure it out? If you have the same code what did you do to fix the problem? I have a 99 Jetta new body style V6
Old 01-29-2008, 11:58 PM
bisync bisync is offline
HAve '99 vw jetta manual that cuts out at 20 mph or approx 2800 rpm. idles rough and at high rev in idle the gas again cuts out at about 8000 rpm and catches back again once throttle is let up. Can only really drive 15-20 mph before it jerks suddenly and stops getting fuel and then the throttle needs to be let up again. if it is held down i get nothing. Codes pulled read p1580 (vehicle speed or idle speed control, throttle actuator b1 malfunction) and p0103 MAF A circuit high input. could this be a throttle valve sticking or throttle body in need of clean or something like a MAF sensor problem needing a reset or being just plain shot?
