Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-08-2004, 04:01 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Re: Compression after 1k boosting!!!
Originally Posted by D-Bo
man, go to synthetic.. i changed at my second oil change since i got my car and it makes a huge difference.. it revs much more smoothly, idles quieter and more smoothly, overall a better feel from the engine.. i use that and 93 octane to keep deposits out of my cylinders.. i'm gonna rebuild in a few months anyways but its good to have a clean driving car.. and who did you guys deal with for your injectors? is there a specific brand thats more favorable than others?
I already am running synthetic. I changed to synthetic at 120k.
Originally Posted by GT500916
he KA stock pistons are forged, and they dont have to be replaced unless you go over 350-400hp... some people take the stock rods and shotpeen them to make them stronger to hold up to 400+hp , i know a guy who got 400hp on his stock KA engine, i was all holly crap you are nutts!! but we know how our KAs are so strong. I just thing they made these engines for turbo and then just forgot to throw turbos in there on the assembly line... they probably had a little misprint, like KA24DE instead of KA24DET , its ok everyone makes mistakes...
but i personally would change my rods when i turbo mine, because my goal is around 400hp and to be safe..
i still dont know my compression on my KA, whats stock compression? and how much are those pressure gauges?
The KA stock pistons are cast, not forged. 400whp on a KA is the result of very precise tuning via stand-alone. The rods are forged and only need to be shot-peened to hold big numbers. Stock compression is 179. I think it is the synthetic causing higher readings. Don't forget to warm your engine up first. I am running 5w-30 so that may be why I get a little consumption. I'm probably gonna switch to 10w-30 next oil change.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 12-08-2004, 04:04 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
hey fanatic, dont you want to buy lower compression pistons if ur upping ur boost that much? i always thought that was neccasary to do when ur getting past 8 psi?
Old 12-08-2004, 04:14 PM
Tims_240's Avatar
also, since i think you know alot about this stuff, a stand alone system was mentioned. do you need a computer to tune it? from what ive read, it replaces the ecu right? im talking about the aem ems btw.
Old 12-08-2004, 06:40 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
couple people asked....
the KA24DE is running a 9.5:1 comnpression ratio. good compression for moderate boost. but without a good way to cool the air coming into your engine from the turbo i would not run high boost. in most peoples cases, that want to run high amounts of boost, it is a lot easier and less worries just to lower the compression. as long as yor prevent pinging, you can run a good amount of boost on top of your stock 9.5 to 1 compression ratio. water/alky injection on top of a nice FMIC should allow you to run a good amount of boost. just remember to upgrade everything that needs to be upgraded to prevent detonation also. (fuel injectors are a must)
ZedEx Crew Member #4
Old 12-08-2004, 08:10 PM
lucki17 lucki17 is offline
could poor idleing be caused by bad oil? i just got my car back from it being in the shop for 3 month and now it idles horrable, and every once in awile when i stop it will go down to 500rpm or so, im probably putting cheap napa sinthetic in soon, but will it help me?
Old 12-08-2004, 08:25 PM
johnnyboy5's Avatar
johnnyboy5 johnnyboy5 is offline
Send a message via MSN to johnnyboy5
so the higher the compression the better? or the closer to the stock compression the better? What happens if its too low?
Old 12-08-2004, 10:08 PM
D-Bo's Avatar
D-Bo D-Bo is offline
for turbo, lowering the compression is an easy way to prevent overheating, and i thought i heard something about turbos being more effective with lower compression.. and if its too low then ignition will not be as complete, therefore taking power away
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 12-08-2004, 11:10 PM
240SX Guy
The lower the compression, the higher amount of boost you can run. What it really comes down to is engine strength and precise tuning. I saw a civic in Dsport running 10:1 pistons and 29psi boost! Head design and headgasket thickness can also be factors. If you run a lower compression ratio, you have a larger margin of error when running more boost. Think about it, all you are really doing when you run more boost is increasing the compression. I believe higher compression ratios will also give quicker spool times. Not sure on that one though.
Objective of compression test is to get factory compression.
I believe AEM EMS does require a computer to tune. Its windows based software.
Poor idling is probably basic tune-up stuff. Search for tune-up and you should get some ideas of what to try. I doubt switching to synthetic is going to cure your idle problems. The switch isn't very noticable but your engine will thank you later. Before I switched, I pulled my valve cover off to find scored cam lobes. About four months after I had switched to synthetic, I pulled the valve cover off to find nice shiny cam lobes with no score marks. Its good stuff.
You shouldn't make less power to avoid overheating. Lowering the compression isn't how you should avoid overheating. If you are overheating, there is a problem in your cooling system. It should be fixed pronto because overheating can lead to detonation or preigntion. Neither of those are your friend. And when running highly tuned FI systems, you should run some kind of timing management system that allows you to adjust timing on a curve. I believe Greddy E-Manage has this feature.
-Cory
12.6@122mph
Old 12-08-2004, 11:29 PM
Z Cars Fanatic
preach on!!! if your motor is built tough enough you can run high compression with high boost. most drag cars throw a huge blower on top but still run a high compression ratio. this is the reason why they have to rebuild their engines after every track day. ok think about it this way...when you add FI your essentially adding compression to your engine. so lets say your running a 9.5:1 stock compression and 8 psi of boost. that might add up to a total of maybe a 13:1 compression ratio (i had a chart but i cant find it so just take my word i guess). now at that point your putting some good power down. but if your engine isnt built for that 13:1 compression ratio it is gonna destroy itself. this is why people lower their compression so that they can up the boost because it is a more efficient set-up. also, it is a safer and more reliable method than adding a shit load of compression and a little boost. this is also why most factory turbocharged vehicles come with a less than 9:1 compression ratio, its mroe efficient and reliable. there are ways to get around detonation and pinging without lowering the compression but at some point you have to stop.
Old 12-08-2004, 11:39 PM
240SX Guy
The difference is when you run a turbocharger, you are making more power by flowing more air unlike raising compression. Raising compression makes the engine run more efficiently by allowing it to burn fuel more completely and/or run higher octane fuel. No increase in displacent(unless of course you oversize which is almost necessary. Try finding a company that makes stock spec high compression pistons).
-Cory
12.6@122mph
Old 12-09-2004, 12:05 AM
Z Cars Fanatic
how much boost is the stock KA able to handle once a FMIC is installed??? just wandering.
a 10.5:1 compression engine is no fun at all, ill tell you that much.
Old 12-09-2004, 12:21 AM
240SX Guy
No set limit. I know so far the "pro" KA tuners, so to speak, have found that the ring lands give out around 400ish whp. On an average joe car, expect them to hold to around 300whp. After that, your on your own. Expect days of full day dyno tuning and plenty of money.
10.5:1 is no fun.
-Cory
12.6@122mph
Old 12-09-2004, 12:45 AM
Z Cars Fanatic
10.5:1 is no fun.
that is very impressive. nissan rules all!!!
yeah i have a 10.5:1 compression ratio on my z32 n/a. the most i could do is possibly yank the turbos and manifolds from a TT and try to cool that air as much as possible and just hope i can run a few psi. not worth the time nor the money, IMO.
Old 12-09-2004, 01:58 AM
TatII TatII is offline
a good FMIC will help you run more boost. however its just one of the things required.
i have a decent sized FMIC and i will not venture past 9 psi with my current setup.
you still need fuel, and some sort of hack into the ecu to accomidate for timing retartation and for fuel enrichment.
my FMIC is good for 400hp but like i said earlier, i'm waiting for my larger injectors, and jwt tuned ecu to come in the mail. then i will know for a fact that i will be safe to run that on my stock engine.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 12-09-2004, 02:22 AM
GT500916's Avatar
GT500916 GT500916 is offline
Banned
Send a message via AIM to GT500916
Re: Re: Re: Compression after 1k boosting!!!
my bad yea i ment the rods ...
