Old 12-14-2004, 01:11 PM
JasonSpaeth JasonSpaeth is offline
I thought about this. But I did not smell any gas on the dip stick...probably a good idea though.
Old 12-14-2004, 01:19 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 95 Blazer Hard start when cold
Not probably, it is a definite thing to do when you swap them in.
The longer you wait, the more damage you are doing.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-15-2005, 11:48 AM
Help! I replaced my CPI unit and nut kit about a month ago. It solved the problem and has been running well. Recently, though, I have been smelling gas. Today, I removed the plenum and found puddles of gas on both sides. With the key on, I am unable to find any leaks. Where is this gas coming from? I checked each of the poppets and they are "clicked" in tight. Are these poppets susposed to have an Oring? - I don't remember seeing them on the old unit. Do I have a defective unit?
Old 01-15-2005, 03:27 PM
BlazerLT's Avatar
AF -Advisor
No o rings for the poppets.
You indeed might have a bad injector.
Did you use o-rings for where the nut kit inserts into the injector?
Old 01-15-2005, 03:36 PM
Yes...I used Orings between the nut kit lines and the injector unit. I just went and exchanged the CPI unit for another new one and installed it. Will drive it tonight and hopefully I will not smell gas when we return back into the garage. I also changed oil again in case it had gas mixed.
Old 01-20-2012, 06:06 AM
RMD1183 RMD1183 is offline
Originally Posted by BlazerLT View Post
Replace your oil ASAP.
It is impregnated with gas.
Trust me on this, also don't use a fram or pennzoil oil filter.
Hello,
I have a Lumina APV with a cold start problem also, and was just researching other posts when I read yours. I am curious: why not a Fram or Penzoil filter? What oil filter do you recommend?
Thanks!
