Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 12-12-2004, 09:38 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: clunk?
The nut kit doesn't come with the CPI, you can get it at the dealer for about $45.00, the CPI you can get at advance autoparts for $270.00
Old 12-12-2004, 10:31 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
Re: clunk?
don't have a advance auto thats local. ok. at least i know what to pay for the nut kit. i thought it might be around $100. i'll pick it up tomarrow.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 12-13-2004, 04:58 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: clunk?
gmpartdirect.com has them too.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-13-2004, 10:31 PM
Re: clunk?
picked up the nut kit and the CPI. CPI cost about $342. the nut kit from dealer was $64. i'm putting it in tomarrow. i'm going to follow s10's wedpage on how to do it.
Old 12-13-2004, 10:34 PM
BlazerLT's Avatar
AF -Advisor
Re: clunk?
You will also need a new plenum gasket.
You CANNOT just reuse the old one.
Old 12-13-2004, 10:43 PM
Re: clunk?
what about using sealent on both sides. worse case i'll get one tomarrow. can you tell me what a ping sounds like on a motor?
Old 12-13-2004, 10:53 PM
BlazerLT's Avatar
AF -Advisor
Re: clunk?
Only use the plenum gasket, do not use sealant EVER.
Pinging is in most cases undetectable and can only be detected by the knock sensors.
In bad cases it will sound like metallic rattling coming from your engine when you for instance are going up hills.
Old 12-13-2004, 11:03 PM
Re: clunk?
could a bad CPI make it sound like a knock to the motor on start up? 5-10 mins. once the oil starts flowing? the best way i could tell you is it sounds like a piston knocking. but its only there when its cold. or could the lifters be doing this?
Old 12-13-2004, 11:35 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: clunk?
Nope, it won't cause that.
What you might be seeing damage caused by racing an engine with fuel laden oil.
The damage might have already been done.
Old 12-13-2004, 11:38 PM
Re: clunk?
what could have gone bad? it always been there since i got the truck. the person before me never raced it so i don't think thats it. it only does on start up and i think that if something was really gone it would at least do it under stress. could it be carbon build up in cyinders?
Old 12-13-2004, 11:42 PM
BlazerLT's Avatar
AF -Advisor
Re: clunk?
What grade of oil are your using?
Old 12-13-2004, 11:44 PM
Re: clunk?
10-W-30. Mobil 1 true syn. cold ol can get as high as the mark in between 40 and the red line. normal idle is just below middle mark and above 1,000 RPMs is at the middle mark or just past.
Old 12-14-2004, 02:31 AM
BlazerLT's Avatar
AF -Advisor
Re: clunk?
Ok, well, for one, what temperatures is your area seeing lately?
Secondly, your engine calls for 5w30. Why you are running 10w30 is beyond me and is probably causing the cold start knocking.
You sure you don't have a Fram oil filter installed?
Old 12-14-2004, 09:36 AM
Re: clunk?
its in the 30's. it does it in the summer too just not as bad. i'll try to get some 5W30. and yes its not a fram since i won't use one using syn. since they only last about 3 months where i need mine to last 12.
Old 12-14-2004, 01:21 PM
BlazerLT's Avatar
AF -Advisor
Re: clunk?
Once you have fixed your CPI and nut kit, I would swap in a new run of oil.
Chances are your oil is really screwed up with gas. You might not smell it, but it is there.
