Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-07-2004, 08:16 PM
smokin' joe smokin' joe is offline
Banned
Re: Re: I need help 400 rear wheel horse power is not enough
Originally Posted by BLU CIVIC
how many more times are u gonna post what u have done to ur car?
I'M 15 AND CONCEDED WHAT DO YOU EXPECT. INCASE YOU DIDN'T GET IT THE FIRST TIME HERE YOU GO HERE IS THE DEAL I KNOW HALF THE PEOPLE PROBABLY DON'T BELIEVE ME THAT I HAVE 400 HP WELL MY CAR IS RUNNING 12.4 FLAT THE GUY THAT DID ALL THE WORK GAVE ME A LIST SO HERE WE GO THIS IS ALL OFF MEMORIE
DRIVE TRAIN
BORED .30 OVER
BALENCED AND BLUE PRINTED
MOLY COATED FLAT TOP PISTONS
SHOT PENNED PUSH RODS
BALANCD AND POLISHED
LUNATIE 420 LIFT CAMSHAFT(I LOVE THAT SOUND)
ROLLER LIFTERS
ROLLER ROCKERS
STAGE 3 4BBL HEADS
WIAND INTAKE
4BBL HOLLY 750 CARB.
HOOKER LONGTUBE HEADERS
FORD C-4 TRANNY (OUT OF SOME SORT OF DRAG CAR)
3200 STALL CONVERTER
ALUMANUM DRIVE SHAFT
FORD 9" REAR END WITH 3:55 DETROIT LOCKER
EXTRAS
FIBERGLASS HOOD
THANKS FOR ANY COMMENTS
  #17
Old 12-07-2004, 08:45 PM
Banned
Originally Posted by eillob
P.S im 15 and a sophmore so Nitros is not an option i would be in BIG trouble.
Dude with 400 HP Im suprised your not in trouble already especially at your age. You sure your making that kind of power? When was your last dyno.
DYNOED WHEN IT WAS FIRST BUILT AND IT WAS WAS 435 BUT MY MOTOR HAS A FEW HUNDRED MILES SENCE THEN SO I JUST SAY 400 BUT PEOPLE STILL DONT BELIVE ME
  #18
Old 12-07-2004, 09:42 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
I'd still like to see a chart. Here's why I'm so skeptical:
Shot peened pushrods? Uhh, you mean polished/shot peened/ARP'd connecting rods, right?
420 lift cam? That's barely bigger than a stock 2.3L 4 cylinder cam.
Now, the fun part. If you are seriously making that HP out of that motor at under 6000 RPM, you don't have stage 3 4BBL cleveland heads. The stock cleveland 4BBL head had ports that were too big to be usable on the street i.e. under 7000 RPM. Flowed too much and killed torque production. 2BBL heads have about the right size ports but too open of a combustion chamber, requiring domed pistons. Not a big deal, but it's added reciprocating mass. Enter the "Aussie" heads. Small ports, closed chambers. Voila'! Big power.
That 750 is borderline too small for your motor. The combo I mentioned above would be fine, Clevelands breathe big for a 351 cubic inch motor. It would really pound out some torque if you got a 400M crank and had it turned under to fit your main journals, and got the right rod/piston setup. You'd have a 406, and running around 10.5:1 compression with the right cam/intake you'd get 450 HP pretty easy.
If you have a full roller motor that is balanced and blueprinted, I wouldn't be scared to rev it. If properly built that sucker would live in the mid 7000's to 8000 RPM...but your carb will choke it off that high.
BTW pics of my Cobra are at http://www.cardomain.com/id/mccobra94
I have run a current traction-hindered best of [email protected] MPH, running just over 300 HP at the crank. With a head swap, tremec trans, slicks, and some intake port work I expect to run mid-high 12s on a 3500 lb car.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
  #19
Old 12-07-2004, 10:24 PM
eillob's Avatar
eillob eillob is offline
Ahhh, I think that would be check mate.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
  #20
Old 12-07-2004, 10:28 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
GG game set and match!
  #21
Old 12-08-2004, 12:01 AM
wildstringer's Avatar
wildstringer wildstringer is offline
well the sad thing is that it sounds like he hasnt done anything to the car . I thought he said some guy did all the work to it . who is driving this car at the track to get those times ? do they let 15 yr olds race. best thing i could tell you to do is sell the car . not sure if you are ready for that kind of power you say you have. learn all you can so when you are ready you can do as much of the work to your car as possible and go to sleep at night with a sence of pride
BTW when your head is done spinning after Ace's statement think of some new bedtime stories for us all
"If the devil danced in empty pockets, He'd have a ball in mine "
87 LX 5.0 - I'm not even going to say what I've done to the car cause when I see how much more I want to do I wanna cry.
Closed Thread
