Old 12-11-2004, 08:03 PM
BobM46128 BobM46128 is offline
Re: Re: 98 Knock Knock
Originally Posted by BobM46128
If it is on the pasenger side, it may be a vapor canister valve making the noise. at least the Express vans have this problem. There is a service bulletin about them I believe. The symptom is that it sounds just like a spark knock.
It is actually called the Evaporator Purge Solenoid according to my Service Information. The suggested remedy is to replace the valve. Apparently the old valve makes this noise when the valve seats.
Old 12-15-2004, 02:06 PM
Arrowshooter Arrowshooter is offline
What is a vapor canister? And where is it?
Old 12-17-2004, 07:47 PM
acewelderman's Avatar
acewelderman acewelderman is offline
knock
Mine started out as a knock on acceleration and ended up being a blown head gasket and two cracked heads at 105,000 miles. Could also be carbon build up quieting as the engine gets hot. Pull your egr valve and check for carbon build up. I'm leaning towards cracked heads, you will need to do compression check to verify. Bear in mind, I am a TIG welder/laser operator but these are problems that I just had on my truck.
Thanks, acewelderman
Old 01-11-2005, 02:15 PM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Re: 98 Knock Knock
This is piston slap, IMO. As piston expands, knock typically gets quieter, or goes away completely. If it was a bad rod bearing, it would knock all the time. A little psiton slap is no big deal. My 98 Silverado has some. Hell, my fresh 468 race motor has some too, although forged pistons are more susceptible to the slap than cast, as bores need to be bigger to allow for extra expansion of forger pistons. Cast pistons expand less, so bores can be tighter, but still piston slap is a fairly common thing.
Old 01-11-2005, 06:13 PM
Fireplug Fireplug is offline
Re: 98 Knock Knock
Pistom slap will not be there after the engine is up to operational temps. GM piston slap is a very old problem hell the 2.2, 3.1 just to name a few had that problem and it was always on a cold (first)start up then go away as the engine warmed up.
This might sound dumb but there was some talk about bad pcv valves cause this problem and we did replace a lot under a very quite recall
