Old 12-14-2004, 10:01 AM
bjwand bjwand is offline
Send a message via AIM to bjwand
Re: Re: Could be a bad sensor also.
Originally Posted by GMMerlin
Which one?
Yeah, that's the problem. There are so many sensors feeding that computer. If the code says you've got a fuel mix problem you'd need to check the sensor that detects the fuel mixture. I don't have the maintenance manual so I couldn't tell you. You can start by pulling and cleaning the sensors one by one. I believe the fuel misture sensor is on the exhaust manifold and it is probably rusted/corroded. Cleaning may not be practical. Those sensors can be kind of expensive, also.
Old 12-14-2004, 12:47 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Question:Warnings
Originally Posted by slacker_53
Hey Merlin, what's the fuel cap code? I can't remember and don't have my manual handy.
-slacker
There is no "fuel cap code"
There are codes for the evap system depending on if it is a small of large leak. Either one can be caused by a loose gas cap.
The problem is most people automatically assume that it is the cap and won't go as far as to test the system integrity.
Case in point..I get called to the Service Managers office on morning..in his office is a customer who is cussing mad..been to 2 different dealers for a reoccuring SES light on his Grand Am...everytime they have told him it was a loose cap.
I take the car and do some diagnostics..found the seal on the top of the tank pinched causing a leak.
Replace the seal and clear the code..no more problems..plus gained a new customer
Too many times people automaticly assume without checking the basics first.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-14-2004, 03:03 PM
nineball481's Avatar
nineball481 nineball481 is offline
Re: Re: Question:Warnings
I wish more people took the time to actually do their job. It seems too often that people take vehicles in and describe the problem and the dealer either doesn't believe them or pawns it off as not their problem.
I'm an electrician and often have to trouble shoot other peoples work when a problem occurs. Like you said Merlin, take the time to look it over and you will find usually a small easy to fix solution for the problem. Then come out looking like a hero because you take a little more pride in your work than the person before you.
Sorry for the little rant, but I believe it to be true.
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 12-14-2004, 03:51 PM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
seems like i read here that the fuel cap code was similer to what he suggested maybe the 174???????????jj
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
Old 12-14-2004, 06:22 PM
GMMerlin's Avatar
I know stuff
P0171 and 174 are fuel trim lean codes...mostly caused by a vacum leak.
I have found a few intake gaskets leaking (vacum not coolant) causing this also a crack in the plastic upper intake can cause this.
GM WCT
PM Me for details
Old 12-14-2004, 06:46 PM
catback23 catback23 is offline
Which one?
I wouldn't jump to the conclusion that the sensor is bad but with the mileage it's probable...the sensor would be the O2 sensor (tells the computer whether the fuel mix is lean or rich)
Old 12-14-2004, 08:25 PM
GMMerlin's Avatar
I know stuff
You missed the humor in that post
GM WCT
PM Me for details
Old 12-15-2004, 09:55 PM
Yea looks that way. In my own defense it didn't appear funny just odd.
Old 12-17-2004, 06:22 PM
Mulaka Mulaka is offline
Chevy place read the codes P0171 and P0174 and then checked all hoses and seal etc.. They found nothing. They say they are 99.9 % sure it is the fuel pump. Thoughts?
Old 12-19-2004, 08:34 PM
Bump
Old 03-11-2005, 05:04 PM
Z71K9KOP Z71K9KOP is offline
Send a message via ICQ to Z71K9KOP Send a message via AIM to Z71K9KOP Send a message via MSN to Z71K9KOP Send a message via Yahoo to Z71K9KOP
Did anybody find out what the problem was? I have this same issue. The exact same codes! Looked over everything. No one can find it.. errr!!!! Always seems to run fine though.. Just that SES light drives me nuts!!
Old 03-14-2005, 03:28 PM
weapons138 weapons138 is offline
Are you using a K&N filter?
I am having the same prob. and codes.
Replaced the fuel filter and the light came back.
I was told that the oil from the K&N will cause the mass air flow sensor to get dirty.
Old 03-14-2005, 03:31 PM
I was told that the oil from the K&N will cause the mass air flow sensor to get dirty. My fuel economy has also went to the dumps.
Going to clean the MAF, and put a paper filter back in. Hope it works, and is not the o2 sensors, they are not cheap. Let me know if the same is for you.
