Old 12-05-2004, 08:43 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Check engine light...
I only used one O2. I had the shop clogged the second hole on the down pipe.
Old 12-06-2004, 09:34 AM
90hatchsi's Avatar
90hatchsi 90hatchsi is offline
Send a message via AIM to 90hatchsi Send a message via Yahoo to 90hatchsi
Well I took the knock sensor out of my spare block and replaced it in the new one and all seems to be ok. My ECU has stopped flashing me the 23 and all seems to be ok with my electrical system now. Now all I have to do is put my front end back together and have it inspected and I should be able to get my title for it. It's been a rough couple of months but i'm finally feeling like it's going to be a victory. hehe. Thanks for all the help!!
EDIT -- Nevermind, it's still throwing the code. It wasn't in the beginning but after warming it up and everything it's still throwing the damn 23. My idle also seems to be fluctuating from 1k to 2k after my engine warms up. When warming up it runs at about 3.5k RPM...does this seem high to anybody else? I know I need to replace my PCV valve because the one I have now is broken. But I still can't figure out this damn code 23...could it be because it's not wired with shielded wire??
Old 12-06-2004, 11:52 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
yes, shielded wire is a must
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
