#16
Re: H23 vtec horsepower?
Ah yes, I misread that. It would be VTEC; however the stroke on the H23A is quite long, and unless you retarded the ignition timing you'd end up with problems with compression.
Try it out and see how it goes... I'm still skeptical on it working well.
![]() 1993 Mazda Rx-7 Touring Ricer Extraordinaire |
#17
Re: Re: H23 vtec horsepower?
It realy isnt that hard to rip apart a engine and put new parts in, you just need to torque the bolts right and put everything in the right order.
#19
Re: Re: Re: 2.2.and 2.3L engine
Hi there I was wondering if you knew if there would be much difference to change a 2.3L engine to a 2.2L engine... if it would be much work or cost alot of money.... i own a 95 cavalier Z24 and can't seem to find an engine of a 2.3 anywhere for it n i was i wondering if a 2.2 put in would be alot of work...i don't know much about it at all so i thought i would ask your opinion!!!! thanks for your time.... plz email me @ [email protected]
#20
This thead is more than a year old.
dSoc member #67 1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook: 1994 Honda del Sol EG1 S-full VTEC conversion. Buy my Del Sol parts!! |
#21
Re: Re: Re: Re: 2.2.and 2.3L engine
the GM ecotech 2.2 engine is much faster than h22a and cheaper.. check ebay ..you can get a good one for about $1500 ..put that on your cavalier direct swap.. some cars with stock ecotech 2.2 engine can do about 14 seconds on 1/4 miles run.. |
#22
here are some cavaliers like yours. manyou wouldnt believe these piece of shit cars are modified with nitrous shots (NOS system) only and theyre doing 11 seconds on 1/4 mile.. see the site man>>>> http://www.dragtimes.com/Chevrolet-C...slip-1933.html
#23
Once again, OLD thread. And we all know of idiots running huge shots of spray on a stock engine.
Edit: After looking at the site it says he spent 35K on that car just to run a 11.9. Whooo
#24
running huge shots of spray on a stock engine is fine as long as you dont go lean. i can tell you dont know nothing about NOS..
Re: Re: Re: H23 vtec horsepower?
#26
Re: Re: Re: Re: H23 vtec horsepower?
trush me ive done it. you can run hude shots on a stock engines..
and yeah of course theyll fall apart....and so as the heavy duty bullet proof racing engines. the extreme abuse from drag racing causes any stock or heavy duty bullet proof racing engines to fall apart. Quote:
#27
Re: Re: Re: Re: Re: H23 vtec horsepower?
Running that much juice on a stock engine is just begging for a rebuild. Would a mod lock this? Oh wait, none of them get here often enough.
#28
Re: Re: Re: Re: Re: Re: H23 vtec horsepower?
Read my post again. I said you can run hude shots on stock engine. Just make sure you dont go lean. Got it?
Lean A/F ratio causes extreme high combustion chamber temp. Therefore, it fucks up the rods and pistons..Got it? running with correct A/F ratio all the way is the trick. You need to know how to do it and your stock engine wont be begging for a rebuild. If you still dont get it then maybe you should quit arguing with me cus you dont know nothing about NOS. Quote:
#29
Re: Re: Re: Re: Re: Re: Re: H23 vtec horsepower?
Proper a/f ratios or not, running that much spray on a stock engine IS NEVER going to last. This better get locked soon, this is going no where.
#30
honestly, i would swap to a jdm h22.....220hp. and plus it is not hard to find one, but the frankenstein is not worth the time or the trouble
