#16
Re: How to take out & clean EGR Valve?.......
This is a no brainer bud, use a knuckle on the end of the extension for flexibility.
I also recommend you put a bit of paper towel across the end of the socket to hold the bolt into place while you insert it into the hole. BTW, make sure you reinstall with a new EGR gasket.
1995 Factory Blazer Service Manual for sale, PM if interested. |
#17
You are the man BlazerLT!
That paper towel on the tip trick worked like a charm. Yes, I installed a new GP Sorenson brand Gasket for $4 from Advance Auto Parts. The EGR valve is back on and the truck seems to be running great. No loping that I can discern. Good stuff. Thanks again, -- recurve |
#18
no problem, glad to help you, I know my first time was a bitch until someone told me about the papertowel trick.
#19
egr extraction
once the egr bolts are free, can the egr valve be removed without disconnecting the serpintine belt adjuster. It seems it would be a mighty tight squeeze to remove the egr valve. thanks for any help. Marooned blazer.
#20
Re: egr extraction
#21
If you've got an engine like mine (W series) and the EGR is right under the air intake of the plenum, it's a real pain in the neck. I just took the plenum off to get to mine. :/
#22
Re: Re: How to take out & clean EGR Valve?.......
BTW, I hope you replaced the upper plenum gasket when you did that.
#23
Pretty close.
