#16
Re: 1999 ZR2 fuel pump whine????
Well, I would bet you have a Passlock system failure. Pay attention to the security light on the dash and what it does. It should light up and go out. If it stays on or flashes, that's your problem. You can turn your ignition on for 10 minutes then crank it over to get it to start.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
#17
Thanks.....I will keep a close eye on that......Are you sure I have passlock though??? My key doesnt have a chip in it or anything.....And, I had a extra key made at wal- mart awhile back and it works fine.....
#18
scan the ecm and get that check engine light code. the ticking is most likely from the engine sitting and the lifters have no oil pressure. that is usually normal if a motor sits for a while. dont worry about it as long as it goes away within 10seconds or less. which gauge doesnt work?
#19
WEll, then go to the Autozone and get the codes read and come back here with the number you got.
We need the exact number.
1995 Factory Blazer Service Manual for sale, PM if interested. |
#20
Will do...thanks again for everyones replies.....
BTW..It the gas gauge that doesnt work... |
#21
The gas gauge doesn't work?
#22
Yea...busa_4 wanted to know which gauge doesnt work.....It stays on E and low fuel light is on
#23
If you are having problems with both the pump and fuel gauge I would guess there is a problem at the connectors to the pump/pickup. If that connection is craped out it might cause both problems. Just an idea.
#24
dont quote me on this but i think if you disconnect the connector to the fuel gauge sending unit the fuel gauge should red full (high resistance) and if there is a short in the circuit (low resistance) the fuel gauge should read empty. check this out! look under the vehicle and make sure no wires have been crushed, damaged, or shorted out. also, check the connectors for damage or corrosion.
#25
Ok...got the code.....P0452
#26
Well.... I found out what it is...i reached ontop of the pump and moved the wires around...trying to get the gage to work......and turned the key on and the pump didnt come on...moved the wires back to were they were and the pump come on......I gues its the connector or a bad wire.....So...I assume thats why the gage isnt working also?????
#27
P0452 Evaporative Emission Control System Pressure Sensor Low Input
#28
p0452 low input. that code is because there is intermittent voltage to the tank pressure sensor. fix the wiring/connector problem and clear the code. it should not come back on when problem is fixed.
#29
Thanks very much for everyones help.......
