Old 11-12-2004, 01:57 AM
AndonD454's Avatar
AndonD454 AndonD454 is offline
Send a message via AIM to AndonD454
Re: Which of these subs would you get?
personally im sure even one 15 will blow the old system away sq and spl... but abotu the 2 15s.. i would measure out your trunk before you consider it too much.. those 15 mentioned above require huge boxes if there ported (or sealed for that matter)
Old 11-12-2004, 02:03 AM
threedd97's Avatar
threedd97 threedd97 is offline
Send a message via ICQ to threedd97 Send a message via AIM to threedd97
I will probably go with 1 15" for cost reasons. I don't want to take ALL of my trunk space. I found a reseller of U.S. Amps and found these:
USA-1000
USA-1000X
Which is better?
UNOFFICAL AUDIO BRAND RATINGS
My life is composed of the worst luck known to man.
Disclaimer: My knowledge of car audio is questionable, but it usually sounds great to me.
'98 Grand Prix GT 4Dr
'06 XXX 12"
Possibly a Cadence ZRS-10
Pioneer DEH-5500MP
Old 11-12-2004, 02:07 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
The XXX you can buy factory direct from www.reaudio.com, they don't have prices on there but the 15" is around $430 shipped and the 12" is around $380 shipped. As for amps, the lowest prices for Cadence used to be at www.usacaraudio.com, but I have no idea what happened to that site. I haven't found a good replacement site yet, but there are a few authorized dealers on www.caraudioforum.com who can get you a good deal (you'll have to run a search on there though as I don't know who specifically the dealers are), and the lowest prices I've found for US Amps is www.speedsound.com
Were those 10's ported or sealed? Actually either way a ported XXX 15 will....god I can't even come up with a good metaphor, it's too late. Are the Cobalts the C-series? If so a single XXX 15 will have the same linear displacement as 8 of the 10" C-series, it will be absolutely no contest.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
AndonD454's Avatar
i suppose in my opinion.. the 1000x.. only because if youre buying a XXX or Brahma.. they will be dual 2 ohm... unless you talk to the company and specify otherwise.. and the dual 2 can only be run at 4 ohms or 1 ohm
Old 11-12-2004, 02:09 AM
sr20de4evr's Avatar
USA-1000
USA-1000X
Which is better?
You'll need more power than that for a XXX
but to answer your question, the 1000X would be better as it provides full power at 4ohm instead of 2ohm (the XXX is dual 2, it can only be wired to 1 or 4 ohm)
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-12-2004, 02:10 AM
threedd97's Avatar
Re: Re: Which of these subs would you get?
That is where I found the US Amps at. Great prices. Which amp would be better for one XXX 15", the Cadence or US Amps?
'06 XXX 12"
Pioneer DEH-5500MP
sr20de4evr's Avatar
damnit I'm just too slow tonight.....
'01 Black Sentra SE
'05 Silver WRX STi
AndonD454's Avatar
also, though, check those sites sr20 just gave because i think i would want to find a mono amp that was stable at 1 ohm to run the 15 with.. maybe 2 ch. is better but ive always been told monos are the best sub amps
Old 11-12-2004, 02:12 AM
sr20de4evr's Avatar
well, I would rate US Amps slightly above Cadence, the problem is US Amps only has 1000 and 2000 watt models, the 2000 watt one would be better for the XXX but it's nearly $1000. In that regard I would say that Cadence would be the better choice, you can get a ZRS-8 or Z7000 for around $600, either of which would give you 1500 @ 1ohm
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-12-2004, 02:14 AM
AndonD454's Avatar
good suggestions.. makes me wish i had the money for an amp like those
Old 11-12-2004, 02:15 AM
threedd97's Avatar
Sounds great. I guess I'm going with the Cadence 1500 @ 1 ohm with a XXX 15". The reason I'm penny pinching in a way is because it'll just take me that much longer to purchase a more expensive setup. Will I need a second alternator or battery? Or just replace my Walmart battery with an Optima Yellowtop?
'06 XXX 12"
Pioneer DEH-5500MP
Old 11-12-2004, 02:19 AM
AndonD454's Avatar
i would suggest the yellowtop/redtop for sure.. not sure how many amps your alternator puts out.. but regardless i wouldnt suggest another.. but rather a rebuild or replacement of the one you have.. if necessary.. i dont know thats another couple hundred so lets see what sr20 says
Old 11-12-2004, 02:21 AM
sr20de4evr's Avatar
what size is your stock alternator?
on a car that big I'm guessing it will be around 100 amps, that paired with a yellowtop and the magic 3 upgrade should hold you over. I have the same amp on a Brahma 15 in my car, on the stock battery and stock 80 amp alt. When it really gets going it will drag the system voltage down into the 12's, but at that level it's almost unbearable to be in the car, and that's just sealed. I can't even imagine what it would be like ported, the words "retarded amounts of output" come to mind. Haibane can shine some light on the subject as well, he as a XXX 15 on an eD nine.1 (~1500x1) and he enjoys it.
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-12-2004, 02:27 AM
AndonD454's Avatar
how is 1500+ watts running on an 80 amp with a stock battery not killing your car? my friends truck with a sotck battery is 80 amps and he cant even turn his volume up with a 1000 watt fosgate amp without it killing it
sr20de4evr's Avatar
oh, and if you're curious, I have some pics of the ZRS-8 (since the pics that are on their site suck)
http://www.resnet.trinity.edu/areyno...io/zrs8_01.jpg
http://www.resnet.trinity.edu/areyno...io/zrs8_02.jpg
http://www.resnet.trinity.edu/areyno...io/zrs8_03.jpg
http://www.resnet.trinity.edu/areyno...io/zrs8_04.jpg
http://www.resnet.trinity.edu/areyno...io/zrs8_05.jpg
I would say it's the highest quality amp I've ever owned, but after buying the Linear Power, that would be a lie
'01 Black Sentra SE
'05 Silver WRX STi
