Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-14-2004, 06:17 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: need help locating EL reverse gauges for..
you can try it and see if moving your needles fixes it, but it might not.
Had the same problem in my friend's GF's MX-3. It was always off by about 30 mph, tried messing with the needle some, but since the needle doesn't move unless you hit the gas it didn't do shit for it.
If it was like the temp guage or gas guage where the needle moves when you turn the ignition to ACCII or what ever you have, you could go about calibrating them, but for RPM and speedo it seemed like it was impossible.
Empty Pockets Racing Member #1
Old 11-21-2004, 03:37 PM
Sean Price Sean Price is offline
Send a message via AIM to Sean Price Send a message via Yahoo to Sean Price
Re: Re: need help locating EL reverse gauges for..
is anyone here familiar wit honda civic gauges particularly the clusters? are the needles not supposed to be removable or what? when I took them out i had not problem and so when i ws replacing them i got careless and jus put them in and the gas one snapped leavin me no needle for the gas... my thinkin and correct me if i'm wrong on all this..
..is I jus need to take evrything apart again, remove the mph and rpm's needles put them back on make shure they are set to ZERO THIS time, replace the entire gas cluster wit a new one....
pi yow! simple as that right? or am i wrong? wht can be so hard about that? besides dange of snappin the other needles?
thanks all
one
Sean Price
keepin it real/packin steeL/gettin high/cuz life's a b*tch and then u die....
Old 11-22-2004, 04:04 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Mind I ask why you removed the gauge needles? The needles are not supposed to be removed. There is really no reason you should have had to remove the needles. Also, removing them, moving them around, this can all mess up the gauges accuracy. If you removed the needles and then broke one, you'll need a new cluster. You have a DX? If so, those clusters arn't a lot from a junk yard (sites have been listed already) as they arn't in great demand due to a lack of a tach.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 11-22-2004, 02:44 PM
I removed the needles... to install some custom gauges that were EL reverse guaages...now keep in mind this was when i was a ROOKIE..and about 5 years ago..when NO one was really doing this ie. BEFORE it became popular so there was no one else to go for or info on it..the shops in my area told me i was on my own.... UNfortunately i found out the hard way ONCEi was done an they was ruined that all i had to do was slip the new gauges over the OLD ones...man was i p*ssed...you DO learn the hard way i guess..so thats where i"m at now... have mph and rpm gauges that are at least mph 40 miles off... and a no needle on my gas cluster meanin I NEVER know when to put gas in until the yellow gas light comes on... oh and i have an ex auto sedan...2000
so DO you think i should attempt to repair this? of jus leave it be? i did purchase a new gas cluster can't i jus pop that in? and as for the mph and rpm's should i jus settle wit them being off and compensate it by adding the 40mph for the speed? let me know what you all think..this has to be repairable..
thanks all
one
Sean Price
Old 11-22-2004, 04:36 PM
Honda God
thanks all
one
There ARE speedometer repair shops, I suggest you call one up and talk to them. I talked a long time ago to a giuy here that owns a speedometer reapir shop. He fault out said many Honda guys in the past have come in twith ruioned gaugers when they installed indiglows wrong (bumping, messing with, or removing the needles). He said once it was screwed up, you needed a new gauge cluster more often than not. It shouldn't run you more htan $135 on a high for a gauge cluster, try searching the sites or calling the places I gave last time. For the most part, that's not usually something that is repairable though, when the gauges are off due to someone messing with the needles. Usually you'll need a new gauge cluster. However, if you are worried sabout all this, I suggest calling a speedometer repair shop if there is one in the area.
As I said, 40mph off on tne speedo, no gas needle, rpm's off. YOur gauge is SHOT, you need a new one. CHeck out auto adventure and Acura-Honda U-Fix-It (phone number on the previous page) and
www.car-parts.com
Once you get a new cluster in, I suggest taking it to a speedo shop anyway to get the accuracy of the new unit checked. It usually doesn't run more than $15.
EPR Member 4 Life
