Old 11-09-2004, 10:35 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: what can i do to the 305 in my camaro to give it more power.
Originally Posted by tacoma man.
damone6969, my camaro has a 5 speed, how much horse power do you think that them mods will give me?
i couldnt tell you exactly.. itd be more than 250hp though.. and it'l chew that 5speed up like cheerios
1991 Camaro Z28
Old 11-09-2004, 10:45 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Ok, back on subject, if you have the LO3 then domone said will do fine, except it's a holley 670 TBI. Except I wouldn't go with the edelbrock performer rpm cam, I think it has a lil to much lift for what your application, the performer cam would best sute you, or call up comp cams and get them to grind you a cam from there xtreme energy series. If your only wanting 250 horse then you don't need new heads, the ones you have will be fine. I'd get the w/p sr torquer 305 heads if you where going with some bigger numbers. But for 250hp I'd get the holley 670, edelbrock performer intake, xtreme energy cam, edelbrock TES headers, headman cat and flowmaster cat back. that should do you good. That might actualy jump you up to about 260-265hp Another good mod is the TB spacers and the injector spacers. Also since your spending money, get an MSD 6A or 6AL box, blaster coil, cap&rotor and some 8mm wires.
Old 11-10-2004, 01:16 PM
LSGun LSGun is offline
theres a website that sells a 335 stroker kit for a 305 it gives you loads of power over stock. I thought about that for my old TPI 305 in my old IROC.
That and headers, bigger throttle body, and intake setup. You would be at 250 hp easy.
Old 11-10-2004, 03:21 PM
DaMoNe6969's Avatar
Re: Re: what can i do to the 305 in my camaro to give it more power.
Originally Posted by 1992RS
If your only wanting 250 horse then you don't need new heads, the ones you have will be fine. I'd get the w/p sr torquer 305 heads if you where going with some bigger numbers. .
see thats what I thought too.. But i figured once he built his engine up to about 250-260hp, he would go completly mad with the urge for more power.. more more more..
1991 Camaro Z28
Old 11-10-2004, 07:12 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
hopping up the 305 in front of a stock T5 is not really a good idea. basily youre looking to put the power of an L98 motor in front of the tranny, which GM already decided was a bad idea, enough so that they didnt do it. If you are gonna hop up the 305 then get a different trans to back it up.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 11-10-2004, 09:45 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
well now i see that any way that i go with making my car more powerful im going to have to upgrade the tranny. it would be cheaper to just buy a good used t-56 and drop in my 350, and use the extra cash to buy the holly tbi unit and what ever else i will need
Old 11-11-2004, 09:46 AM
89IROC&RS's Avatar
sounds good to me
Old 11-12-2004, 12:15 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
headers and bigger exhaust would help
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 11-12-2004, 03:45 PM
i already done the exhaust deal, just made her growl a little louder. i had done that 2 years ago. the 5 speeds in the rs's are geared to low in 1st and second gear anyway. i have a 307 hp 350 that i got off of a friend and it only has 4500 miles on it.
im going to drop it in there and bolt a 6 speed to it.
Old 11-13-2004, 11:08 AM
89IROC&RS's Avatar
that sounds like a good deal
Old 11-13-2004, 06:06 PM
I don't think GM decided not to put the T5 behind the L98 because it was a bad idea mechanicly(sp). I think they did it because of other reasons uforsean. And didn't the L98 Vette come with a T5? But if you remember I ran my T5 upwards of 400hp with out a problem.
As far as saving money by dropping a T56, your in for a surprize, it ain't reall cheap, trust me I just went throught that. From tranny mounts, driveshaft, torque arm& bracket, cutting the shifter hole bigger, and all that. Worth it, but not cheap.
Old 11-15-2004, 03:39 PM
i just went and got my t-56 from out of my firebird saturday, also im going to try and use its ws6 suspension so im covered. im going to knock on wood, cause im not going to be out much money on this one.
the engine and tranny are already pulled from my rs, got that done sunday, today i cleaned up the enginebay and getting her ready for her new engine and tranny.
