Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Cosmetics
Cosmetics interior, exterior, wheels.
Old 06-10-2001, 07:16 AM
poppy_morenito's Avatar
poppy_morenito poppy_morenito is offline
Send a message via AIM to poppy_morenito Send a message via Yahoo to poppy_morenito
That is nice looking the wheels tuck in perfectly ....
Old 06-10-2001, 07:38 AM
kenchan's Avatar
kenchan kenchan is offline
momo- what off set are those wheels? I may have to get me a set. hehehe. yep, first turn the adjustment knob all the way clock wise (full hard). and then turn it back couter clock wise 14 clicks. if it seems too stiff still, turn it to 15th click . depending on the spring rate, you don't want to go 16clicks. also, the knob will keep turning up to 24 clicks counter clockwise, but do not go over 16clicks. it was only meant to be used up to the 16th click.
you may notice some clunk noises from the dampers, but that is from the air bubbles accumulated from shipping. after you break it in, the clunk noises will gradually dissappear as the airination (sp?) is complete. btw, I put an order for those typeNA's myself directly to TEIN just last Friday. hehehe.
Old 06-10-2001, 10:30 AM
P10DET's Avatar
P10DET P10DET is offline
Dude, you are potentially looking at trouble with the lower grill shut off like that. Even if it is some sort of mesh, it will block a significant amount of airflow.
If you are going to use a mesh, you should use a more open mesh. A good friend of mine has a degree in aerodynamics and said any mesh impeeds air flow. If yours is mesh, it appears to be *very* small openings. That will seriously impair airflow.
I'm not dissin your ride, but don't want to see you have problems.
Geo
Old 06-10-2001, 05:19 PM
primera man's Avatar
"P-Man"
Geo
Yeah, i wonder about that as well.
I have been reading a few car books here and i see how there is a trend starting by using Alloy sheet plate and only drilling a few hole in it. It may look good all polished up but it cant do much for the cooling.
I have seen a similar problem with guys using those "centreline" mags with no holes etc in there mags and the brakes get that hot they loose there stopping power and start to wrap the disc it self over time due to the lack of air flow around them.
View All My Models Here.
Old 06-10-2001, 09:59 PM
Dillweed Dillweed is offline
momo: My dad does professional auto graphics. Is it a kind of tape they used for that?(the lights)
I know that vinyl tape(2 mil) is the best for that. I thought it was tape but maybe I'm wrong.
Some people are alive simply because it is illegal to kill them.
Old 06-10-2001, 10:33 PM
MOMOG20 MOMOG20 is offline
i don't know what's call!! but it is used by race car only!!!
and it's not white color.. it's carbon fiber white ^.^
Old 06-10-2001, 10:37 PM
Geo
dude it's same as grille craft using!!! and it doesn't bother any airflow so don worry!!!
Old 06-10-2001, 11:32 PM
kenchan's Avatar
momo, please post picts of how you did the trunkliner to get to the rear TEIN damper control knob. thanx. I would imaging you cut around the rear strut tower area so that you have easy access. I'm planning to cut it myself, but don't know which hump the strut's under. hehehe. please post picts of your trunk. thanx
anyone know the offset of that MOMO Sport wheels?
Old 06-10-2001, 11:51 PM
well!!
sorry but i haven't cut trunkliner yet!!! and i don exactly get that how that things work.. sorry..
r u in chicago? where do u live? cause i live in indiana!!
and my wheels are on sale if you want it!!! just let u know!!
Old 06-11-2001, 07:38 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Don't cut the trunk liner....well you can but you don't have to. Just open the back doors, drop the rear seats and there it a trim around the opening behind the rear seats. Remove that and reach between the liner and rear seat to adjust the shocks. You don't really do that enough to justify cutting your liner.
Old 06-11-2001, 09:44 AM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
yeh, I didnt cut my trunk linings either...you can just lift up the trunk mat and the side trunk linings to get to the knob, not THAT much trouble
unless you get a rear strut bar, you dont need to cut up anything
Luke C.
GDA Power!
Old 06-11-2001, 12:38 PM
kenchan's Avatar
guys, thanx for the info. appricate it. yah, I better just leave the liner alone for now.
how hard is it to get the trunk liner off for installing the TEIN's? I haven't taken a real close look at the liner yet, but is it just held together to the chassis with those clips with the center pin you push in to release? how many? thanks a bunch
momo- I'm in the nw suburbs of chicago. I go to kokomo, IN once in a while for business. I don't usually buy used wheels. why are you selling them?
Old 06-11-2001, 12:59 PM
1hotwhip 1hotwhip is offline
Send a message via AIM to 1hotwhip
eyelids
Where did you get the eyelids for that? Also where did u get the clear sidemarkers?
Old 06-11-2001, 01:03 PM
both custom works!! ^,^
Old 06-11-2001, 01:13 PM
If you sell your wheels , you wont be MOMOG20 anymore will you ?
Unless you get another set of Momo's .......
