Old 11-08-2004, 08:03 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Which one?
no way the GSR will handle as much boost as a B18B, simply because of 9.2:1 compression vs. 10.1:1 compression. Best stock motor to boost is the B18B hands down. If you were to build internals it's still a toss up. With a B18C you want to lower the CR, but if you do that you lose power. And about the cams, turbo cams have less duration and valve overlap, VTEC cams are usually designed for more lift and duration, kind of defeating the purpose there again throwing in turbo cams in a VTEC head.
Empty Pockets Racing Member #1
Old 11-08-2004, 08:05 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Which one?
Thanks GS, i guess whoever i heard that from was wrong, what u said makes sence.
Old 11-08-2004, 08:07 PM
GScivic7's Avatar
Re: Which one?
Honestly, for power though I would so go with a B18C, but most people on here aren't building drag cars, they are building street cars. A turboed b18b would be perfect for a street car. The B18C does have a lot of good things going for it for a drag motor. High redline, block girdle, oil squirters for the pistons and the extra oomph from VTEC, all good things for a drag car, but for street car you want torque basically, the B18B will give you that.
Old 11-08-2004, 08:10 PM
Kind of a Big Deal
Re: Which one?
Again, very true, but i guess im biased because im building a drag b18c...
Old 11-08-2004, 08:14 PM
drumpet15's Avatar
drumpet15 drumpet15 is offline
Re: Which one?
Thanks for the info. I'll definitely do some more research on my own, but that helps tremendously!
Old 11-08-2004, 08:15 PM
Kind of a Big Deal
Glad we could help
