| Exterior and Wheels This is the place for all exterior wheel modifcations. |
#16
Re: Re: Im tired of this!!!!!
so if i raise the car up it might help out the ride?
![]() Something new is coming... |
#17
it could if you haven't already blown out your GR2's.
Dr. Disque - Current cars: 2008 BMW 135i M-Sport 2011 Mazda2 Touring Past cars: 2007 Mazda 6S 5-door MT 1999 Ford Taurus SE Duratec |
#18
okay yesterday i scraped the bottom of my front bumper coming out of my driveway. i forgot i couldn't pull straight out, and i had to turn to the right and come out an angle.
I tell you what i'm so sick of this low riding bullshit!!! all i do is bounce around all the time. i had my sub box bolted down and i broke the bolts!! the subs go air borne daily! its not even funny! anyways i set up an appointemnt on the 6th at this custom place, that does everything from turbo kits to body kits. they assure me they can raise it up and get the ride quality better.
#19
97 Eclipse GST MT ![]() Race Every Day Like It Will Be Your Last. My one insignificant mod: Dump Tube - CUT |
#20
what i noticed that my gs was way bouncy and rattlely, but my spyder is way softer. it takes the bumps and the railroad tracks way better.
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
#21
KYBs should not be used on 2G DSMs, according to RRE.
Also, these cars arent made for an especially comfortable ride. I have 225/45/17s at the moment, and my ride is very rough. I had the same ones on my 2" dropped spyder last year, and the ride was terrible. Then I rode my firnds 96 gst on stock rims and tires, and the ride felt much smoother. Then again, when I drive my 92 Accord, it feels like a luxury sedan, lol. 2G eclipses do have a rough ride man, i think it just comes with the territory....once you start modding, there isnt much u can do to help your ride comfort. |
#22
you don't understand how bad it is! i hit my head off the ceiling!!! my sub box jumps off the floor air borne after breaking 2 screws holding it down.
plus my girlfriend hates the car because of this, and won't ride in it. this car is my baby, i can;t have my girl hate it.
#23
make sure your tire pressures are set right.
shpyder: the less sidewall a tire has the harsher a raide its going to give. tires on 17's have much harder sidewalls so they dont absorb bumps as well.
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
#24
well i got my ride rasied today. Apparently it was so low that the coil overs weren't even working. so i was basicly riding on just shocks. the numb-nuts who installed it was clueless because it hurt the handling and traction.
The results are that it's lowered now only by 1" on the coilover, and 1.5" physically lower than stock. but i'm not sure what its considered in terms of how much its lowered. its about a side skirt higher than it was before, and now that my springs are working the ride is SOOO much better. Easyer to get in and out of, traction is a lot better, wheel hop is gone, and it feels like the car has a suspension when going over bumps. it now sits level instead of the engine wieghing down the front. the styling of the eclipse still makes it look a little lower in the front but all the tire gaps are the same. overall i'm very happy with the results. and by some miricle the shocks are still good. although their life is probably greatly diminished due having to support to whole cars weight for however long it was like that.
![]() Something new is coming... Last edited by TreeFrog; 01-07-2005 at 10:29 PM. |
